EMERGENCY HELP!!! Flooded interior...
Discussion in 'Technical Chat' started by kriskross, Mar 31, 2014.
  1. Apr 11, 2014 at 7:22 AM
    #141
    BamaToy1997
    Bill
    Navarre, FL
    Marion, Alabama. About 4 hours north of Destin, Florida
  2. Apr 11, 2014 at 8:57 AM
    #142
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    the first thing you need to do is check if it has spark, and if it doesnt that needs to be your main concern. because that you KNOW. everything else is just a guess.
    dont just go replacing the fuel pump without knowing you for sure need one or not.
    dont waste money!
  3. Apr 11, 2014 at 10:58 AM
    #143
    kriskross
    kriskross [OP] Shits & Giggles
    Monterey
    Former 2ndGen Owner, in the market for another
    See Build Thread
    Looks like I was smart and kept my comprehensive insurance. I also get $30 per day for a rental car up to $900. I still have to talk to an adjuster, but it looks like all I'll have is a $500 deductible, as long as they don't total it.
  4. Apr 11, 2014 at 7:22 PM
    #144
    kriskross
    Monterey
    See Build Thread
    Did that!
  5. Apr 11, 2014 at 7:24 PM
    #145
    SpruceTacoChris
    SpruceTacoChris Well-Known Member
    Las Vegas!
    13 DCSB TRD Offroad
    BAMF Sliders
    I really hope it works out for you, good luck!
  6. Apr 11, 2014 at 7:40 PM
    #146
    4runnercaged
    cody
    arizona
    LOL
    Good luck man!
  7. Apr 11, 2014 at 8:59 PM
    #147
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    They will.
    If it's covered.
  8. Apr 12, 2014 at 6:58 AM
    #148
    tony2018
    tony2018 Well-Known Member
    So wait, you swapped ecu's. Did you reprogram your key to it? Remember, immobilizer. What I would do is try to read the new ecu via obd2 scanner. IF its functional than we can go from there. Then you'll need to check for fuel pump priming, if it isn't than you need to check ignition power to relay to pump, very tedious. If you're not up to the task than you'll need to take it to a mechanic because at this point you'll need to hunt down everything that would make the engine start, and I'm not talking about cranking. This means from key cylinder, to both ignition 1 and ignition 2 relays, to fuel pump and to the ecu. Ignition 1 and 2 go to different paths.
  9. Apr 12, 2014 at 7:03 AM
    #149
    tony2018
    Thats not bad, just don't go taking the alternative route to get there faster, meaning going into more offroad paths.
  10. Apr 12, 2014 at 7:44 AM
    #150
    BamaToy1997
    Bill
    Navarre, FL
    :p:p:p Truth!
    Hopefully OP, the insurance will take care of it for you. Sadly though, they may total it out. Let's hope you can get it towed to a dealership and they can get it fixed with a few simple things. Remember to swap back in your original ECU!
  11. Apr 12, 2014 at 8:45 AM
    #151
    kriskross
    Monterey
    See Build Thread
    I don't nearly have the kind of expertise to do all that. That's why I'm resorting to insurance. As long as they don't total it, all I'll end up paying is a $500 deductible.
    I put all original equipment back in. That way I can probably return the ECU I bought or just sell it for close to the same price. They said they will take it to one of their inspectors to determine the repairability before they take it to a mechanic.
  12. Apr 12, 2014 at 10:06 AM
    #152
    TacoMater
    TacoMater Member
    Robert
    Clearfield Utah
    11 DCLB TRD Sport 4X4
    Kenwood DDX-512, JL HD-900, JL 13TW5 Diamond Audio Speakers Coil Over Leveling 1 3/4
    Chris, this is encouraging. Maybe if they total your truck, you can get a newer one to use as an over lander. Then do a buy back or get a cheap older one and make it into your beater truck, like what you were saying lastweek. Win. Win. :cool: :D
  13. Apr 12, 2014 at 10:09 AM
    #153
    kriskross
    Monterey
    See Build Thread
    I've already been looking into the best overland vehicles. Funny thing is, Tacoma's are usually in the top three of any overland vehicle list. Maybe I'll buy your mini-Toyota
  14. Apr 12, 2014 at 10:46 AM
    #154
    TacoMater
    TacoMater Member
    Robert
    Clearfield Utah
    Oooo! Not for sale. But maybe you could find one similar.
  15. Apr 12, 2014 at 10:50 AM
    #155
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
  16. Apr 13, 2014 at 6:12 AM
    #156
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    My opinion is that you should hope for a total. Water/flood damage gets totalled easily for a reason. Once electronics are submerged, the damage may not show up for some time, corrosion grows over time and you may end up chasing gremlins for the life of the truck.
  17. Apr 13, 2014 at 12:36 PM
    #157
    kriskross
    Monterey
    See Build Thread
    We shall see. I wouldn't be too upset. I would probably do a buy back or whatever to keep the truck, get a new one, and transfer all my mods to the new one and part out everything I don't.
  18. Apr 13, 2014 at 1:54 PM
    #158
    tony2018
    With hidden damages they will total it out. Electrical issues are a pain and require many hours of diagnose. There really is no alternative because after the electrical is resolved you'll need to resolve any issues that will arise from rust development, which will require body/frame work. Yeah its a high possibility.
  19. Apr 13, 2014 at 4:23 PM
    #159
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not to mention, every hour that engine sits without getting up to operating temperature, the bearings, rings, sleeves, and camshaft are getting a heavier and heavier layer of surface rust.
    Electronics = Toast
    Engine = Extremely shortened life... if it was not damaged in the initial flood.
    Frame and body = mud and other organic material hidden in inaccessible places, organic material will decompose, generating heat and releasing acids that will promote corrosion.
    Seems costly to buy it back just to save the mods unless the buy back cost is extremely low.
  20. Apr 13, 2014 at 4:37 PM
    #160
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I buy salvaged Toyota trucks. Flood vehicles are always the cheapest vehicles to buy.
    Kriss, I hope you do get it totaled and you do buy it back.
    I want to thank you for not being afraid to start this thread. You know you are going to be paying a "stupidity" tax, yet you still carried on with the thread. Good on you. YYou learned from experience what you can not do with a Tacoma and many others have as well.
    I'm not good with the emoticon thing, but verbal "beer chug" is coming at you.
    Later
    Kirk
