EMP proofing your Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patrickockander, Feb 13, 2012.
  1. Feb 13, 2012 at 1:22 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think he's implying that you're feeding the trolls :rolleyes:
    Sure, they look cute and cuddley now... but you can't give them any positive reinforcement!
  2. Feb 13, 2012 at 1:56 PM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    I have a few thoughts.
    If it's a high altitude nuclear based EMP, then all bets are off. We've got some projections on what the implications might be, but it's never really been done so, who knows. Some projections have such a device putting out about a peak of 6MW per square yard at 50,000 volts over a few microseconds. Sort of like a static shock from rubbing your feet on the carpet. In the worst case, it could be a nationwide event, depending on a number of factors.
    So, it could fry your electronics - but shielding from it would require a reasonably sturdy faraday cage with an excellent ground. Lead would work, but it's heavy as hell - not that it matters, as a good solid ground sort of precludes it being mobile anyway. Copper or steel would be a better choice. And you'd have to shield the whole truck - it's no good to have a friend O2 sensor or something render your truck un-drivable.
    But that's a nuclear device - which Iran likely hasn't got. And a delivery mechanism, which they definitely haven't got.
    So, what about nonnuclear EMPs ? Well, they aren't anywhere near as effective - they generate much smaller pulses and without the benefit of the magnetosphere, so the affected area is much smaller and so is the delivered power.
    EM phenomena diminish as the cube of the distance (non directional signal strength is a function of volume, after all) so the farther you are from it, the better off you are. I doubt you'd even notice it a few miles away even if they got it 5-10 miles up. And if it's ground based, you could measure it in blocks.
    Anyway, the same shielding problems apply.
    Granted, this is speculation - but I highly doubt Iran would use an EMP on us. Just not enough bang for the buck. If they could deliver a device that can generate any meaningful EMP, they'd be better off actually blowing something up with it.
  3. Feb 13, 2012 at 2:03 PM
    ATweezy
    ATweezy Well-Known Member
    Brad
    Arizona
    11 Red RC 4x4
    Grounding out your entire truck is probably a bad idea. The ground could actually act as an antenna during this pulse and induce a current that would fry various electronic components. Your best bet would be to construct a faraday cage of some sort. They came in all different shapes and sizes and different materials. It just needs to obviously be a conducting material IE aluminum. Think about a microwave and what its job is. It acts like a faraday cage, keeping harmful waves from mostly escaping. Ever wondered what that mesh screen is on the door of the microwave? That screen is absorbing most of the waves from inside the microwave.
    Your house is not an adequate cage and does not have good attenuating capabilities. An ammo can could act as a good cage as well, but that will mostly depend on the seal around the lid (like a gay transformer, you want metal on metal contact). A cheap way to test attenuating capabilities is to put a radio inside the can with it turned on and close the lid. Can you hear anything? You could also use a cell phone to test its ability to attenuate. Put the cell phone in the can and close the lid. Does the phone now go straight to voicemail? The cell phone test wont work if you have AT&T as they are already unreliable and you wont know if the can is really attenuating or not... LOLZ
  4. Feb 13, 2012 at 2:09 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    If you did, you would be the only person on the road with a working vehicle and you'd look like a jerk off like Tom Cruise did on War of the Worlds.
  5. Feb 13, 2012 at 2:09 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    only way to do it would be to build a faraday cage and park the truck in it and then never drive it because what happens if your at work and an EMP goes off? well that F cage that you built at your house wont do shit...
    So basically there is nothing you can do to "EMP proof" your tacoma...or any new car.
    If you are truly worried about it then you need to go buy something like a '82 or older vehicle.
  6. Feb 13, 2012 at 2:26 PM
    KingMoo
    KingMoo Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    underwater bases for the win!
  7. Feb 13, 2012 at 2:37 PM
    Redfox1
    Redfox1 'Stralia! Riding Roo's and wrangling koalas
    Conner
    Santa Paula, CA and SLO
    09 Prerunner Sport TRD
    Browning Floor Mats, 275/70/17 BFG All-Terrain T/A's, Procomp 7089 wheels,Rear Spring TSB, Bilstein 5100's, LED roof light, seatbelt chime disabled, CB, UWS Toolbox,
  8. Feb 13, 2012 at 2:47 PM
    saundern
    saundern Swerve for nothing
    Nick
    Simpsonville, SC
    2005 TRD Sport
    why would worry about Iran using an EMP on us when APPARENTLY they have nukes.
    Even if they were dumb enough to use a nuke anywhere in the world, hell would ran down on them from every corner of the globe, including those 45 bases surrounding them.
    Its called Mutual Assured Destruction, a form of Nash equilibrium.
    So, an EMP would be the least of our worries like everyone has already said.
  9. Feb 13, 2012 at 2:50 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Its all about bullets man.
    It is way better to invest in guns and lots and lots of ammo. See the thing is when you have a neighbour up the street that has wasted his time and money to emp proof his shit all you have to do is go over there with a .223 rifle with the 100 round drums on it and say gimme your shit or die. Its just that simple. Now with your new ride you can go around the town and rape and pillage everyone.
    Just remember guns and bullets.
  10. Feb 13, 2012 at 2:52 PM
    saundern
    Nick
    Simpsonville, SC
    2005 TRD Sport
    x2 :infantry:
  11. Feb 13, 2012 at 3:06 PM
    Eagledynasty
    Eagledynasty The White Knight
    AJ
    Worcester, MassHole
    09 Super White DoubleCab Off-Road
    2009 SWDC O/R. Check Build!
    This is a little of a stretch OP.... I don't think you should worry about EMP's. Have you been playing Call of Duty a lot lately. If you want to be serious... You should have made a thread about zombie proofing your truck. Havent you seen the Walking Dead? You wake up in the hospital one day and the whole world is under zombie attacks
  12. Feb 13, 2012 at 3:07 PM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    Let them laugh now OP. When we are the only ones on the road getting to a safer place, it is us who will have the last laugh.:D
  13. Feb 13, 2012 at 3:10 PM
    Eagledynasty
    AJ
    Worcester, MassHole
    Better put some women in the Tacoma EMP blue prints or you guys will be pissed your the only 2 left
  14. Feb 13, 2012 at 3:17 PM
    Utard
    Mark
    Nyssa, Oregon
    Bullets will take care of the zombies.
  15. Feb 13, 2012 at 3:17 PM
    #35
    Derpy Derek
    Derpy Derek Well-Known Member
    Derek
    Brookings, OR
    2012 TRD Sport 4x4 DCSB
    ARB Bumper, Smittybilt X20, King suspension
    :notsure:
  16. Feb 13, 2012 at 3:17 PM
    #36
    Utard
    Mark
    Nyssa, Oregon
    With lots of bullets it will be my truck.
  17. Feb 13, 2012 at 3:26 PM
    #37
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You guys sure solar flares are just tin foil conspiracy, because that Jan storm knock few networks down. Most vulnerable are those third world places running old unshielded wiring.
  18. Feb 13, 2012 at 3:33 PM
    #38
    Panther
    Panther Well-Known Member
    Kaiden
    BH, ME & BOS, MA
    2021 TRD Sport DCLB
    OEM lift. Ditch lights
    Simple. Horse mod:
  19. Feb 13, 2012 at 4:51 PM
    #39
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Switch all the electronics over to over to vacuum tubes.
  20. Feb 13, 2012 at 5:02 PM
    #40
    Lost_Humanity
    Lost_Humanity Bad decisions make great stories.
    Seattle
    It's a Toyota.
    Bumper Dent Mod
    I for one will welcome our new Iranian overlords.
