Enclosure brainstorming..would this work? Anyone tried it?
Discussion in 'Audio & Video' started by ABA180, Nov 23, 2012.
  1. Nov 23, 2012 at 10:31 PM
    ABA180
    ABA180 [OP] It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    OK, I have a pair of 12's in my regular cab (not shallows). I'm hitting the seat lever in the back, so I'd like to get something thinner than the enclosures I have now which are 19 1/4 inches wide.
    It looks like I'd need about 3 inches thinner or so to clear the lever.
    The height of it is only 15 inches, so it looks like turning the box on its side would work. Problem is it's an angled box *grr*
    Seems like a thinner but taller box would clear the lever if it was built that way. Has anyone found something like this? I'd rather not go custom if I don't have to, just rather not dish out a fortune..I can't imagine I'm the first truck owner to deal with this and I'd rather not replace my subs to the tune of several hundred dollars.
  2. Jan 8, 2013 at 11:28 AM
    pinktaco808
    pinktaco808 Hot Steppa
    pics man and what kind of subs?
  3. Jan 8, 2013 at 11:31 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I see your problem....two 12's in a regular cab:eek:
  4. Jan 8, 2013 at 12:24 PM
    ABA180
    East Bridgewater MA
    Click the pic icon, I posted a couple.
    Trying to make it work if I can, it beats having to buy new speakers if the ones I have work just fine.
    I have Polks now, can get a set of MTX's.
  5. Jan 10, 2013 at 8:02 AM
    SlowComa666
    SlowComa666 Well-Known Member
    San Antonio TX
    2014 SR5 Access Cab 2WD
    you could just do what we did in the old days, make a blow-thru
    cut a hole in the bed and cab, run wide camper shell accordion seal on both edges to mate the cab and bed.
    now you have the entire bed to make a proper sub box.
    you may want to have a locking tonneau cover before this.....
  6. Jan 10, 2013 at 9:40 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Just rebuild the boxes. Keep the same volume. Should be simple math to find the current volume and then build new ones with the same airspace. This works just fine.
