Engage LT bolt torque specs
Discussion in 'Long Travel Suspension' started by SoCalRoadie, Jun 19, 2011.
  1. Jun 19, 2011 at 12:22 AM
    SoCalRoadie
    SoCalRoadie [OP] Well-Known Member
    Jim
    Burbank
    10 PreRunner TRD 2wd Engage LT
    I was supposed to bring the truck back to Engage after 100 miles to double check bolt torques but I miscalculated and won't get it back to them till 200+ miles. I have all the sockets and a torque wrench but not the specific torque ratings for the Engage kit. Anyone know what they might be? Thanks in advance.
    Jim
  2. Jun 19, 2011 at 12:28 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  3. Jun 19, 2011 at 9:10 AM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
    Who needs torque spec? Just tighten the bolts as tight as you can get them. Iv never had a problem with my suspension parts. only bolts i use torque spec are lug nuts and ubolts. Iv never had an issue with something coming loose.
  4. Jun 19, 2011 at 6:06 PM
    vitang
    vitang Well-Known Member
    diamond bar
    07 TRD Sport 4wd
    Engage Front Long Travel, Giant Rear Long Travel, KR Fab rear bumper, tire gate and Jerry Can cage.
    X2. Just go over everything to make sure nothing is loose.
  5. Jun 19, 2011 at 6:18 PM
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
  6. Jun 19, 2011 at 6:26 PM
    SoCalRoadie
    Jim
    Burbank
    Cool. i just don't want anything wiggling loose on the way there. Everything looks ny-locked so it should be fine. Thanks everyone!
  7. Jun 19, 2011 at 6:46 PM
    Socalrunner
    Glendora
    Icon Coilovers
    IF you have the race spindle. Check the bolts that hold the caliper on. Mine came loose
  8. Jun 19, 2011 at 6:52 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Its not just vibrating loose. New bolts stretch after the first time they are tightened. Just because it didnt turn doesnt mean it isnt loose
  9. Jun 19, 2011 at 8:50 PM
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    the bolts will loosen the first few times you head out. Make sure you check them everytime you roll out. tightening them is fine.
  10. Jun 19, 2011 at 8:57 PM
    in2nite
    James
    SoCal.
    blk 07 prerunner
    Jim what front fenders do you have. I want to go wider on the front.
  11. Jun 19, 2011 at 9:56 PM
    SoCalRoadie
    Jim
    Burbank
    I just don't want anything falling out in the next 50 miles till I get to Engage... :)
    I have the GlassWorks 6" fenders and I really like the extended coverage.
  12. Jun 19, 2011 at 10:11 PM
    in2nite
    James
    SoCal.
    blk 07 prerunner
    thanx just found them on the glassworks website....
  13. Jun 19, 2011 at 10:13 PM
    Socalrunner
    Glendora
    Icon Coilovers
    Im going to be getting those to James. These ones dont even cover the tire
  14. Jun 21, 2011 at 8:33 AM
    SoCalRoadie
    Jim
    Burbank
    Here is a front pic of the 6" fenders. I have the 16" TRD rims with a 1.25" Spidertrax spacer on stock spindles.
  15. Jun 26, 2011 at 7:01 PM
    in2nite
    James
    SoCal.
    blk 07 prerunner
    Im going to pick up a set also... Ill prob pick them up in a few months. also going to have the tailights filled in. im on for 4th tail light. going led..
  16. Aug 10, 2011 at 11:53 PM
    Deanthemachine
    Deanthemachine Well-Known Member
    07 Prerunner
    when I took mine in to get tightened up hass just did it by hand til they were tight. if you find a real loose one its good to mark it with a paint marker so that if it loosens up again more then it should it may need replacing
