Engine a bit rough-Seafoam at 180K?
Discussion in '1st Gen. Tacomas (1995-2004)' started by RockTock, Feb 20, 2012.
  1. Feb 20, 2012 at 12:11 AM
    RockTock
    RockTock [OP] Well-Known Member
    Colorado
    1999 2.4 4 Banger SR5
    I just got it, had to fight for it (4cyl 2.4 manual), and hope I did not get a lemon. Compression came back: 150, 145 x3, (which now sounds a bit suspicious)
    But anyway, engine is a bit rough on idle, nothing too bad, and was wondering if I should sea-foam it, or maybe just do some in the engine and crankcase to be on the safe side? (not cylinders)
    Also, I want to check the plug wires, what is the normal Ohm reading on these?
  2. Feb 20, 2012 at 12:33 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Clean the throttle body. New plugs wouldn't hurt either.
  3. Feb 20, 2012 at 8:13 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I have seafoamed my engine twice now. I have read good and bad about doing it. I can tell a huge deference in how much smoother it idles and runs, but on the flip side i have put on new plugs and new wires at the sametime so idk how much the seafoam actually did.
    I would vote new plugs and new wires.
    With 180k the wires unless they have been replaced are probably tired and new ones around here were like 30$.
    Then if this doesnt help maybe try seafoam.
    Just my $0.02 worth!
    Good luck.
  4. Feb 20, 2012 at 11:39 AM
    RockTock
    Colorado
    Ok, thanks- its fuel injected, so where else would you do it? Maybe just gas tank to clean lines, injectors? Maybe get it in the injectors direct?
    Also, I used to use a straw with tape to start out the plugs (so they dont strip the hole) Is there a tool that one can buy to do this with? Or am I just going to make one? I guess I could tape 2 straws together.
  5. Feb 20, 2012 at 11:44 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    No on the seafoam IMO.
    Check plugs, my truck had the originals at 150k and was idling kinda rough. Changing them made a world of difference.
  6. Feb 20, 2012 at 1:35 PM
    RockTock
    Colorado
    Ok, it looks like plugs were changed at 155,000 (178,00 now) -cost only $19.00, so maybe not great plugs, but only 20,000 on them. I will go with NKG plugwires, but I would like to test the ohms first. What should the ohms be, I've read 25,000?
    Now, it seems to run fine on startup, 1000rpm, but when it slows to 750, it starts to rumble and the steering wheel shakes a bit. Is that normal for just plug wires?
    No distributer, just 2 boxes where the wires go, how do I unhook them, looks like a clip of some sort? I think Ill upload some pics.:)
    125,250-
    Oil Ch
    Rear Diff Oil Ch
    Manual Trans Serv? 98.00
    129000
    Charcoal Canister
    Evap control Canister
    $478
    155,200
    Spark Plugs
    Water Pump
    Power Steering Fluid
    Radiator Hoses
  7. Feb 20, 2012 at 1:47 PM
    erik559
    erik559 Member
    I have a 2.4 and it idles rough. My truck does need a tune up but even right after a tune up my truck idles rough. I dont think you bought a lemon
  8. Feb 20, 2012 at 2:31 PM
    RockTock
    Colorado
    Ever think about using SeaFoam?:eek:
    Here is the plug wire thing. Have no idea how to disconnect.??
  9. Feb 20, 2012 at 2:50 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
