Engine Break-in
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Okkine, Nov 26, 2008.
Engine Break-In
  1. Hard Break-In: Get those RPM's up
    133 vote(s)
    11.5%
  2. Easy Break-In: Keep the RPM's low
    640 vote(s)
    55.3%
  3. Doesn't make a difference
    385 vote(s)
    33.2%
  1. Dec 16, 2013 at 8:56 PM
    #221
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    I had the same problem when I wanted the free oil change at 1k miles instead of the recommended 5k. Since they wouldn't do it I just went home and changed it myself.
    At 1k miles there was alot of metal flakes in the oil. Maybe they don't hurt the engine but I would rather not have them in there.
    RJM
  2. Dec 17, 2013 at 8:31 PM
    #222
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    I did my first oil change at 5000 miles as recommended in the owners manual.
    If you have visible metal flakes in the lube oil, that the oil filter isn't catching, something is wrong with your engine?
  3. Dec 18, 2013 at 8:21 PM
    #223
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    Drive it like you stole it! Don't pussy foot it around town. The cylinder walls need to be broken in hard in the beginning...
  4. Dec 19, 2013 at 4:09 AM
    #224
    TheMuffinMan
    TheMuffinMan Banana Nut
    Coeur d'Alene, ID
    2023 Tundra Limited Crewmax 6.5' 4x4
    This. The old addage of breaking it in slowly is 1/2 for the lawyers and 1/2 true for older cars. For all my motorcycles and cars I've driven them as normal and really only avoided constant cruising for the first few hundred miles, I run the engine through the whole rev range as well. Never had a problem with oil burning. The engines are mostly broken in when they leave the factory anyway.
