Engine clicking at 1st start up of day
Discussion in '4 Cylinder' started by 01tacoprerunner, Oct 30, 2009.
  1. Oct 30, 2009 at 7:33 AM
    01tacoprerunner
    01tacoprerunner [OP] 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    So recently i have notice that when i first start my truck up in the morning there is a clicking in the engine. Its not really cold outside, like 50* degrees f. Its just when i start backing up not giving the motor any gas just idling. O its the 2.7 4 cyl.
    Can anybody tell me how to fix this or what it may be???
  2. Oct 30, 2009 at 7:34 AM
    98tacoma27
    Ben
    Not Beech Creek
    Check your exhaust manifold for a crack.
  3. Oct 30, 2009 at 7:40 AM
    01tacoprerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Really?? the exhaust manifold?
  4. Oct 30, 2009 at 7:57 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yeah, a crack will make a ticking sound. Also, look where the manifold meets the pipe for a small leak.
  5. Oct 30, 2009 at 10:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Or....It could simply be a normal sound...that comes from metal expanding and contracting when its hot/cold. I've heard this similar sound on many vehicles. They'll often 'click' when you shut the truck off and they cool down.
  6. Oct 30, 2009 at 4:36 PM
    def4pos8
    def4pos8 Well-Known Member
    Ohio
    White Tacoma AC 2.7L/5spd SR5
    undercoat, running boards
    Worn valve lifter(s) or solid lifters requiring lash adjustment are another possibility, especially if you're using dead dinosaur for crankcase lubrication. The cooler temperatures make it tougher for oil to reach every little orifice. If you have solid lifters they might be operating with little or no lubrication just after engine start.
    Does the noise go away quickly or does it persist for more than five minutes?
    If it silences quickly, I'd suspect lifters. If it hangs around, it could very well be an exhaust problem.
  7. Oct 30, 2009 at 10:10 PM
    01tacoprerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    It silences pretty quickly, like after i give it gas and go. It only clicks when at 1st idle.
  8. Oct 31, 2009 at 5:08 AM
    def4pos8
    Ohio
    Well then, unless there's some strange bit of emissions gear causing this, I'd suspect it's in the lifters.
    If you have solid lifters, a valve lash adjustment ought to make the noise stop.
    If you have hydraulic lifters, fresh oil, maybe Mobil 1, AMSOIL or another synthetic, will help oil reach the clicking lifter more quickly to eliminate the noise. Beyond fresh oil, you'd have to repair or replace the lifter(s). A good mechanic can isolate an offending lifter but if one is bad, others are likely ready to die. The usual solution is to swap all the lifters.
    Talk this over with a trustworthy, local mechanic or Toyota service guy. Even if you do the work yourself, it's good to listen to other opinions before spending time and money on a repair. The truck's still running so there's no need to rush.
