engine clunks when turned on for the first time of the day
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KingMoo, Jun 28, 2011.
  1. Jun 28, 2011 at 7:38 AM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    my tacoma (2011 trd sport dc sb) only has about 3000 miles on it and it makes a strange sound when I start it up for the first time each day. the vehicle remains in park but after about 5 seconds of being turned on it makes a sound that I would liken to that of a bad transmission shift...
    has anyone noticed this kind of thing before?
  2. Jun 28, 2011 at 7:40 AM
    Xshark
    Xshark Well-Known Member
    Air conditioner?
  3. Jun 28, 2011 at 7:43 AM
    transplant
    transplant resident know-nothing
    theo
    Crestline, Ca
    89 sr5, 99 OR, 11sport, 14 offroad
    no, but im right around the same mileage.. ill be sure to look out for it.
    i mean with 3k on the clock.. what could possibly be wrong??
    subbed for the outcome..
  4. Jun 28, 2011 at 7:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm assuming it does this at idle when you're not trying to put it gear? If so, I'd guess it's the automatic choke.
  5. Jun 28, 2011 at 9:25 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    yes it makes the sound after idleing for about 5 seconds. it doesn't sound healthy but I only hear it once per day...
  6. Jun 28, 2011 at 9:42 AM
    ToddG
    ToddG Active Member
    Todd
    Las Vegas
    2011 4x4 White/Tan
    I have a 2011 with 17000 miles i have noticed a slight knocking nosie in the morning on the intitail start up, nose last for a short time until the motor is warmed up.
  7. Jun 28, 2011 at 11:05 AM
    JKD
    JKD Well-Known Member
    Automatic choke? There aren't any carburetors on this vehicle...
  8. Jun 28, 2011 at 11:06 AM
    JKD
    My vote is on the A/C compressor as well. They can sound a little rough on the first startup after sitting for a while.
  9. Jun 28, 2011 at 11:12 AM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    Liquid refrigerant that has migrated to the evaporator because inside the dash is going to be cooler than behind the grille will slug the compressor on start-up. That is possible.
  10. Jun 28, 2011 at 11:17 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the trans fluid level. Make sure electrical connections are secured on the trans.
    If you wear big boots, look under the steering column/dash above where your toe would hit any electrical connectors and make sure they are secure (I have heard of boots disconnecting the Trans interlock relay)
  11. Jun 28, 2011 at 11:23 AM
    Pugga
    Massachusetts
    :eek: guess I'm a little out-dated...
  12. Jun 29, 2011 at 11:04 PM
    transplant
    theo
    Crestline, Ca
    yes, but fuel injected vehicles still do this. after your engine reaches normal operating temperature your rpms drop and the valve in the throttle body sits normal. until then there is an automatic choke... albeit totally computer controlled.
  13. Oct 18, 2011 at 6:21 AM
    T4C0MA
    T4C0MA Well-Known Member
    Was there ever a resolution to this issue? I'm experiencing the same problem now.
  14. Oct 18, 2011 at 10:21 AM
    T4C0MA
    I run my A/C very frequently... I wonder if it could be caused by slightly low freon?
  15. Oct 18, 2011 at 12:09 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Yeah mine does it too. I drive very little - about 5000 miles a year - and my truck often sits unused for days at a time. It is more pronounced when it's been a few days since driven.
  16. Oct 18, 2011 at 12:13 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Dealership would be my first stop, if it is still under warranty.
    Fink
