Engine cutout at Highway Speeds
Discussion in 'Performance and Tuning' started by Amo-cat3, Jan 26, 2012.
  1. Mar 19, 2012 at 3:24 PM
    Sc00ter
    Sc00ter New Member
    Scott
    Austin, TX
    '04 Tacoma 4wd
    Any update to this thread? My '04 is doing the exact same thing.
    Scoot
  2. Mar 20, 2012 at 7:51 AM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    After being basically pushed away from the dealer i went to a local shop that was recommended by Toyota. They scanned and found no pending codes as i have no CEL light. We did a test drive and could not duplicate my issues (and truck seemed to be running flawlesly at the time). We decided to wait it out and see if the truck starts acting up again.
    The cutout came back a week later and i decided to test my Throttle position sensor with my digimeter by following directions on youtube. I did show a weird voltage drop when moving the throttle butterfly plate. I ordered a used throttle body assembly from an auto wrecking yard and it should arrive this week. I'm going to swap it out and see if my issues clear up, if so I am going to put my old throttle body back on and see if Toyota will give me a new one as i am under warranty until August. Will update.
  3. Jan 30, 2013 at 7:05 PM
    ScottValleyGirl
    ScottValleyGirl Active Member
    Dawn Renee
    Temple, TX
    01 PreRunner V-6
    Update on this? I am having this issue at 2250 RPM and ~70 MPH. I notice it with and without cruise, it seems like most especially when I lift off the gas slightly to slow just a little or to maintain speed if slight downhill grade. Same in cruise. Not so much of an issue if on any grade.
    My symptoms DO have a difference in that my tac will dip from 2250 to below 2000 for about a 1/2 a second, then it pops back up. Makes a nice little cut out/jerk.
    New TPS
    New Fuel Filter
    New Coil and wire assembly (unrelated? issue)
    No codes
    Cleaned Fuel Injectors and Throttle body
    Transmission shop says it's shifting fine and doesnt think it's transmission. Shop guy has been all through it, it's not the computer. Computer not giving any codes.
    I've had it for about 6 years, 60K miles. Total mileage is 130K 2001 PreRunner.
    Ideas?
  4. Jan 31, 2013 at 4:25 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To bad you don't live in Houston. Between myself and a few of my good friends, I know we could figure it out or get you in the right direction.
