engine cutout only on bumps?
Discussion in '4 Cylinder' started by yota new.o, Apr 5, 2012.
  1. Apr 8, 2012 at 10:53 AM
    yota new.o
    yota new.o [OP] Well-Known Member
    joe
    klamath falls oregon
    96 tacoma 2.7 sr5
    fabtech dirtlogic coilovers with all-pro a-arms chevy 63" leaf springs billi 5125 12" extended bore shockins in rear headache rack duplicolor bed armor bumpers kc daylighters front fenders corbeau racing seats custom bed rack
    bump: alternator bearings are just fine there is no play at all down there i took the belt off also and it spins freely
  2. Apr 8, 2012 at 11:02 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Your Truck maybe need long due tune up check everything replace what ever looks bad Or needs to be replaced
  3. Apr 9, 2012 at 1:42 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    So driving to work today the truck acted up again sputtering occasionally at any rpm the only thing I have yet to do is plugs and wires ive fine cap rotor coil fuel filter, I'm very frustrated any ideas at all guys
  4. Apr 9, 2012 at 8:43 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
  5. Apr 9, 2012 at 10:59 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    is it possible that my air intake setup could be causing it. i bought just an adapter plate to bolt to the maf and put a k&n on it?
  6. Apr 9, 2012 at 11:06 PM
    BAMFTACO
    Juan
    Kings bruh
    As long as the vacuum hoses are hooked up you should be good but you could test it out if you still got the stock one
  7. Apr 9, 2012 at 11:06 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    another thing how picky are these trucks to sticking with denso parts. i know my buddy at the toyota dealer says only use denso but is that just him trying to get my business or what
  8. Apr 10, 2012 at 9:15 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    bump: put on old intake and nothing changed, i am now off to get new plugs and wires
  9. Apr 10, 2012 at 10:39 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    plugs and wires did absolutly nothing for it now i have a p1300 code?
  10. Apr 10, 2012 at 10:44 AM
    BAMFTACO
    Juan
    Kings bruh
    What does the code stand for
  11. Apr 10, 2012 at 10:45 AM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    igniter #1 malfunction
  12. Apr 10, 2012 at 4:04 PM
    DarkShark
    DarkShark Well-Known Member
    Clark
    Medford/Southern Oregon
    03 DCab 4wd
    Icons, Camburg and custom stuff......
    Dude I wish I could come give u a hand.
    Hope you figure it out soon.
  13. Apr 10, 2012 at 6:37 PM
    yota new.o
    joe
    96 tacoma 2.7 sr5
    Thanks man I have a new igniter on order but if that don't fix it I'm sending it to the yota dealer its getting sketch to even drive to work
  14. Apr 10, 2012 at 7:19 PM
    BAMFTACO
    Juan
    Kings bruh
    Its gunna suck when you take it to the dealer and ends up something really simple that's always the case I hope everything turns out okay man
  15. Apr 10, 2012 at 9:01 PM
    #35
    yota new.o
    joe
    96 tacoma 2.7 sr5
    Ya this is irritating luckily with working at autozone as well I can try that igniter before I buy ha ha
  16. Apr 11, 2012 at 9:11 AM
    #36
    yota new.o
    joe
    96 tacoma 2.7 sr5
    could it be that it has jumped timing cause i also notice my rpm gauge is about 500 rpm?
  17. Apr 12, 2012 at 6:37 AM
    #37
    Hard
    Hard Well-Known Member
    H
    4X4X4
    I dont think if you jumped timing that it would affect your tachometer. This would be an indication of a loose connection in the ignition system. I assum that since you mentioned the cap and plug wires this is the earlier 3rz with a distributor. I would go through your connections again, maybe looking to see if it changes your tachometer reading so you can find the root cause. If your computer is now throwing a code then that would be a good place to focus on but not neccesarily the main problem.
    I know these problems are frustrating but keep at it and you will learn a lot about your car and will have it running like a top again in no time.
    Oh and go Ducks.
  18. Apr 12, 2012 at 10:22 AM
    #38
    yota new.o
    joe
    96 tacoma 2.7 sr5
    lol thanks man i just tried a new igniter and it really helped it cut out maybe twice and it was very faint, but my old one tested good. on the drive back home with the old one it was constantly cutting out, and now it has developed this real deep squeek almost a grind coming from the motor, loud enough i can hear it in the cab. saturday im going to take it in to be diagnosed. im thinking this is a sign that it might be timw for a new tacoma.
  19. Apr 12, 2012 at 11:55 AM
    #39
    DarkShark
    Clark
    03 DCab 4wd
    Dont say that yet you just put all that money in your lift. I can understand it make you think that now but when you fix it youll love it again.
  20. Apr 13, 2012 at 10:42 AM
    #40
    yota new.o
    joe
    96 tacoma 2.7 sr5
    if i need a new motor you will be coming over here to help put this in even if i gotta drive over there and bring you here ha ha
