Engine Experience
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Okkine, Jun 26, 2008.
  1. Jun 26, 2008 at 3:51 PM
    Okkine
    Okkine [OP] Well-Known Member
    Alberta
    1998 Tacoma, V6, Manual Transmission, 4x4
    Hello All,
    I'm looking at getting the 2WD Access Cab with either the 4 cylinder or V6 engine. With gas prices what they are, I'd rather stick with the 4 cylinder.
    It's mostly going to be using it for every day driving and occasionally hauling camping gear.... no heavy loads and no towing.
    Any thought or experiences with the engine would be appreciated.
    Thanks,
  2. Jun 26, 2008 at 3:59 PM
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    go with the v6 yeeah
  3. Jun 26, 2008 at 4:01 PM
    mainerinexile
    mainerinexile Well-Known Member
    central Maine
    2014 SR5 Access cab I4 4x4 5 spd
    Hello All,
    Thanks,
    Steve[/quote]
    I have the 08 4WD 4 cyl speed, no complaints. 24-26 mpg, driving carefully (you can't get this mileage with the automatic--but the 2WD should get this mileage even if you don't drive carefully. I had a 1995 Tacoma with 4 cyl also, no complaints over 160,000 miles. You'll like the 4 cyl. Can't see any reason for a 6 cyl for your uses.
  4. Jun 26, 2008 at 4:06 PM
    Sodbuster
    Sodbuster Active Member
    I have had the access cab 4X4 with the I4 manual. I picked it up this spring and I have a bit over 5000 miles on it. I love it. I pull a 17 and 1/2 foot Crestliner boat with a 115 horse outboard on it. It works a little to pull it but I'm thrilled overall. The I4 access is rated to pull up to 3500 lbs. My last tank gave me 26.8 mpg. The 6 cylinder is an awesome engine but gas is over $4.00 per gallon where I spend much of my time and every little bit helps.
  5. Jun 26, 2008 at 4:08 PM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    Don't get the V6 with the 6 speed. That's what I got, and it's way too much power for me. The thing just takes off wayy too quick and accelerates too quick on the highway. I even stick 1000 lbs of shit in the bed and it's still too much power. I've actually removed 2 of the sparkplugs so that I can have less power. It's too much for me.
  6. Jun 26, 2008 at 5:29 PM
    Okkine
    Alberta
    Thanks for your input. I've been finding it rather difficult to find any sort of reviews for the I4. They all seem to focus on the V6 and ignore the I4.
    I've definitely been leaning towards the I4 for my purposes.... The mileage seems great for the horsepower offered... but what's on paper is often different from how it actually performs. The first hand info helps.
  7. Jun 26, 2008 at 5:30 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Have to drive it yourself, man. Only you can know your needs. There's nothing wrong with the 4cyl but it isn't for me. I'll give up the 2-3mpg on the highway for more power.
  8. Jun 26, 2008 at 5:42 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    In the reliability ratings I've read before buying mine,there was only one rated higher then the 4.0L Tacoma.The 2.7L Tacoma.!!!!
  9. Jun 26, 2008 at 6:10 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Go with the I-4, sounds like it would suit your needs just fine, or you could try Klowns way... uh ... no :boink:
  10. Jun 26, 2008 at 6:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The 2.7 is a fricken anvil of an engine. I beat mine like it owed me money, and it ran like new till I sold it! Never a problem. :)
  11. Jun 26, 2008 at 6:31 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    The 2.7L has more than enough power for what you want to do. Heck it has 43 more HP than the 2.4L toyota my father used to use to pull a small 5th wheel trailer.
  12. Jun 26, 2008 at 6:43 PM
    BmacTaco
    BmacTaco Member
    Tampa
    2011 PreRunner TRD Sport
    The V6 will get reasonable mileage with a lot more power than the 4. I have an 08 Double Cab V6 auto as well as an 04 4Runner Limted with the same engine, and will get 21 mpg on both. Just depends on your needs.
