engine from my 2002 tacoma
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by 88JayPizzle, Mar 27, 2017.
  1. Mar 27, 2017 at 2:29 PM
    88JayPizzle
    88JayPizzle [OP] Well-Known Member
    pulled this out @ 120k miles. been sitting in the garage taking up space. looking to get rid of it for 300.00 picked up
    im located in bakersfield ca
  2. Mar 27, 2017 at 8:58 PM
    rusho2nd
    rusho2nd Member
    1995 Tacoma 4x4 2.7l standard cab
    2.7l? Was it running when pulled? Would you do crate shipping?
  3. Mar 27, 2017 at 9:01 PM
    88JayPizzle
    2.4. And it was running great.
  4. Mar 27, 2017 at 9:09 PM
    rusho2nd
    rusho2nd Member
    Dang. Really need a 2.7l
  5. Mar 27, 2017 at 11:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    lol saw the ad and thought 3.4 - I would be there yesterday! Great deal for a low miles motor.
  6. Mar 28, 2017 at 12:06 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    Would swap right in still I bet. This is the 2RZ I believe correct?
    Dalandser likes this.
  7. Mar 28, 2017 at 12:06 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah same block huh?
  8. Mar 28, 2017 at 12:07 AM
    SnowroxKT
    Kyle
    Anchorage Alaska
    '18 T4R & '06 F250
    6" lift 40s
    I believe it is the same although not 100% on that.
    Dalandser[QUOTED] likes this.
  9. Mar 28, 2017 at 6:59 AM
    rusho2nd
    rusho2nd Member
    Yeah they would swap right in I guess. Not sure if I wanna lose the torque, would you ship anyways?
  10. Mar 28, 2017 at 9:09 PM
    Db8dippin
    Db8dippin New Member
    Would you sell just the throttle body??
  11. Apr 4, 2017 at 2:29 AM
    88JayPizzle
    man 300 just come get it. shipping on this would be expensive.
  12. Apr 6, 2017 at 5:35 PM
    jacobrippey
    jacobrippey It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Phoenix, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    The 2rz and 3rz have the same head, different block. FYI.
  13. Apr 6, 2017 at 5:44 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I would guess the 2rz block is shorter since it uses shorter rods.
  14. Apr 6, 2017 at 5:47 PM
    Speedytech7
    ゼイン
    5520 E Sprague Ave, Spokane Valley, WA 99212
    93 80 Series LC & 96 Turbo V6 Taco 4WD
    I've done a mod or two
    I thought other than the use of balance shafts the block was the same and the rotating assembly was what changed.
  15. Apr 6, 2017 at 8:55 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Naw. The 3rz is stroked a bit more, and uses a balance shaft.
  16. Apr 6, 2017 at 9:25 PM
    Speedytech7
    ゼイン
    Huh, well that's an interesting choice for Toyota, wonder why they even bothered with the 2RZ.
  17. Apr 6, 2017 at 9:32 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Toyota made a lot of stupid decisions on the early 1st gens. Want to put a v6 in a 4cyl truck!? Engine mounts are 1" off. Want to add power windows? Nope, it is not pre-wired.
    BartMaster1234 and ManBeast like this.
  18. Apr 6, 2017 at 9:32 PM
    Speedytech7
    ゼイン
    Haha I could have told you about those two, looking to put a 1UZ in mine still
    DesertDigger likes this.
  19. Apr 6, 2017 at 9:34 PM
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Because I had an entire parts truck at my disposal, I figured why not! Got it for dirt cheap too. also had power windows, locks, cruise, tilt column, intermittent wipers, and the clock. Not bad for an early single cab.
    Speedytech7 likes this.
  20. Apr 13, 2017 at 8:07 PM
    BikerinBlak909
    BikerinBlak909 Well-Known Member
    SoCal
    96 LT 5 lug
    JD Fab LT kit 3" lift spindles Fox 2.5 x 10" dual rate Deaver F67 SUA, 9" shackles 8.4 prerunner rear end with 4.10 33 AT3 wildpeaks McNeil Fiberglass fenders PRP comp seats Doug Thorley long tube header K&N CAI
    What year was this in?
