Engine Idle Falling at Low RPM's
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheOriginalTXTACO, Dec 4, 2008.
  1. Dec 4, 2008 at 5:18 PM
    TheOriginalTXTACO
    TheOriginalTXTACO [OP] Active Member
    San Antonio, TX
    Unfortunately No More
    3" lift, Extreme LineX, Extang Toolbox Tonnoe, UWS Box, MB Wheels, BFG AT's.
    I'm having a low rpm idle problem on occassion.
    It's been happening for a couple of months.
    Happening a few times each day. My daily work takes me
    over 100mi daily, mostly highway.
    Sometimes at startup it will sputter and responds to giving it gas. Sometimes at a stop sign or traffic lite it does the same drop.
    02 V6 Dbl Cab Prerunner. 119K miles. Timing belt replaced
    at 90 or so. New plugs done recently, originals looked very solid
    considering they had 115K on them. Wires are good. I run with
    a FIPK intake. The only other engine mod is the TRD exhaust which
    is fine.
    It basically will drop rpms to the mid 500's and just seems like it's not
    getting gas. I give it gas and or when I'm moving again and no problem.
    Your thoughts.
    ? fuel filter
    ? throttle body dirty
  2. Dec 4, 2008 at 5:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    clean the throttle body and maf sensor real good.......maf may have some excess oil on it from the intake. also......seafoam the motor........suck it in from the brake booster line....these things should help get idle back as it should be. if not..........spark plug wire could be bad...may look good, but it may not ohm out correctly, and there is a possibility of having a cracked spark plug......i have seen that before too. good luck with the fix man!! hope its relatively easy!!
  3. Dec 4, 2008 at 5:26 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    I had that problem with my 02 Ranger. I tried everything, plugs wires new coil IAC valve seafoam drygas you name it.
    turns out the electrical connector to the transmission (auto) was corroded and the signal to disengage the torque converter "clutch" at idle wasn't getting to it. that was a mo-fo to find.
  4. Dec 4, 2008 at 6:32 PM
    TheOriginalTXTACO
    San Antonio, TX
    Any recommended cleaning product. Thought I might try that first.
  5. Dec 4, 2008 at 6:36 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for the throttle body.......seafoam deep creep spray.....great stuff man. and for the maf sensor......crc has a maf sensor cleaner, or you can use some crc electronics cleaner on it, and let it dry before putting back in the intake line. then, a can of seafoam for running thru the brake booster line. these have worked really well for me.
  6. Dec 4, 2008 at 6:37 PM
    TheOriginalTXTACO
    San Antonio, TX
  7. Dec 4, 2008 at 6:39 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob
  8. Dec 8, 2008 at 10:23 AM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    mine does the same thing and i was going to post one about that also
  9. Dec 8, 2008 at 12:16 PM
    TheOriginalTXTACO
    San Antonio, TX
