Engine keep dying on me when hitting rev limiter on 4 low
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kactacmac, Apr 25, 2020.
  1. Apr 26, 2020 at 4:12 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    At what RPM is this happening?
  2. Apr 26, 2020 at 5:06 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    What speed are you going through 4 low in to smash the limiter. Are you locking it into first gear. Otherwise the truck should shift regardless. 4 low turns off the nannies for those that keep posting to turn off
  3. Apr 26, 2020 at 5:26 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    4lo defaults to TRAC OFF and VSC OFF for the Pro and OR trims only.
    All other trims, TRAC ON is the default for 4lo
    OP profile indicates he has OR, so yes he should be nanny free in 4lo.
    AKGSD likes this.
  4. Apr 26, 2020 at 5:53 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    4 Hi
    Better mud tires
    GreyBaldTaco likes this.
  5. Apr 26, 2020 at 6:02 AM
    kactacmac
    kactacmac [OP] Member
    2019 tacoma trd off road
    2 inch lift kit, body armor hiline front bumper
    well BFg KM3 are pretty good tires in my opinion and 4hi is a no, starting to regret selling my JK
    Gearheadesw likes this.
  6. Apr 26, 2020 at 6:09 AM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
  7. Apr 26, 2020 at 6:48 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm thinking engine speed vs vehicle speed vs throttle position is causing a fail-safe condition. Fail-safe is deactivated when it detects a pass condition...in your case the throttle angle is reduced.
    Stop going HAM and try MTS.
    Go to 4:20
  8. Apr 26, 2020 at 7:04 AM
    FLYH2O
    FLYH2O Well-Known Member
    2016 Tacoma TRD Sport Blue
    The truck is protecting its self from throwing a rod. Its why there is a rev limiter for those that can’t.....drive i guess for lack of a softer term. I would love to see a video of these attempts myself.
  9. Apr 26, 2020 at 7:04 AM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    This circumstance has been documented before. It has nothing to do with traction control as there is no throttle intervention in 4-low. The ECU bypasses throttle input if you hit the rev limiter too hard for too long. It's more pronounced in 4-low since the engine can rev so fast compared to how quickly the transmission can shift. Either lift the throttle a bit to give the transmission more time, or use 4-high.
    ridefreak, mic_sierra, AKGSD and 3 others like this.
  10. Apr 26, 2020 at 7:32 AM
    That one old guy
    Chuck
    Stockish
    So you're in 4lo, you break traction, you matt it, bounce it off the rev-limiter until it's had enough and shuts you down.
    OK, you can't fix that...
    Canadian Caber, SR-71A, Chew and 2 others like this.
  11. Apr 26, 2020 at 7:39 AM
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    KM3 is a fine tire but shit in snow and ice unless you air down a ton. Just not good compound or tread pattern for those conditions.
    In your situation I'd either air down significantly or chain up.
  12. Apr 26, 2020 at 7:45 AM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Why is 4HI not an option?
  13. Apr 26, 2020 at 7:55 AM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    4hi -> neutral -> long press traction control button overhead —> have fun and get through snow.
    shakerhood and VB25 like this.
  14. Aug 24, 2020 at 8:24 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    If you watch around the 7 min mark you’ll see it happen, in sand vs snow
    https://youtu.be/uo74Q_T274g
    Junkhead, helix66 and RedWings44 like this.
  15. Aug 24, 2020 at 8:35 PM
    #35
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    The only real issue with this video was that they never figured out how to disable TC
  16. Aug 24, 2020 at 8:37 PM
    #36
    DavesTaco68
    North Thompson, BC
    2013 Tacoma TRD
    If your used to old school systems you probably figure you can just hop in and giver.
    Junkhead likes this.
  17. Aug 24, 2020 at 8:40 PM
    #37
    RedWings44
    Michigan
    Yeah, for sure. My last truck had no TC and, honestly, if it weren't for the comments on that video, I wouldn't have thought of it either.
  18. Aug 24, 2020 at 8:40 PM
    #38
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    there are several types o rev limiters
    the best is the type that will hold max rpm & rev no further
    U dont have that type
    Ur best move is to NOT bump the rev limiter ..........
    AKGSD likes this.
  19. Aug 24, 2020 at 8:41 PM
    #39
    RedWings44
    Michigan
    Are you sure this isn't Traction Control kicking in? Try disabling it and see what happens
  20. Aug 24, 2020 at 8:46 PM
    #40
    rocky_mountain_dave
    rocky_mountain_dave Well-Known Member
    David
    2009 Tacoma Access Cab 4x4 4cyl 5spd
    Working as designed. Toyota's rev limiter is very intrusive - it doesn't just keep you from grenading the engine, it also aggressively cuts throttle for several seconds. Very unlike a sports car where you can repeatedly bounce off the limiter over and over.
