Engine lag
Discussion in 'Performance and Tuning' started by saltus25, Oct 9, 2013.
  1. Oct 9, 2013 at 6:32 AM
    saltus25
    saltus25 [OP] Well-Known Member
    Graydon
    Angleton,TX
    Flowmaster American Thunder Exhaust, K&N intake, OME 3" lift, Pro Comp Extreme MT2 tires, Mickey Thompson Classic II Wheels, Spidertrax 1.25" wheel spacers, URD short throw shifter, KC 100 watt lights, custom steel mesh grill, halo headlights, Rigid Industries Dully's, SOS Offroad Concepts front bumper, SOS Offroad Concepts custom rear bumper, All Pro and BAMF skids
    Im having this issue with my 07. For some reason, everytime i do an oil change i get this engine lag for a couple hundred miles. I have the regular V6 4.0 with a K&N and cat back exaust but i dont think its a sensor issue. Iv really never experienced a break in period for oil in a gas engine. I hit the gas and the engine kind of boggs down for a couple seconds then it comes out of it and drives normal. And im useing like always castrol syntec and fram filter. Any one have any ideas?
  2. Oct 9, 2013 at 4:55 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Clean the maf sensor?
    May be waaAy off here, but I figure its cheap and easy and u can at least start process of elimination?
    Also clean the throttle body.
    I know u say its when u do an oil change and it clears up...... Do u reoil the air filter every time also?
    Kinda at a loss, but those things I suggested about cleaning the maf sensor and throttle body are good maintenance anyhow.
    As for the filter..... If ur oiling it too much it may have a negative effect.
    I'm sure someone else will come in with better ideas, for now consider this a free bump.
  3. Oct 9, 2013 at 7:28 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I have no idea what that is... :confused:
    But try disconnecting the negative terminal on your battery for about 15 minutes or so, and then reconnecting it. That allows your ECU to reboot fresh and to relearn your A/F operating parameters. See if that changes anything.
    Greg
  4. Oct 9, 2013 at 8:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, but the oil change would not affect that.
    I too am assuming that he is cleaning and over-oiling the air filter.
  5. Oct 10, 2013 at 4:41 AM
    saltus25
    Graydon
    Angleton,TX
    The only thing i do with my air filter is wash it. And i havnt done that in about a month. So that has nothing to do with anything.
  6. Oct 10, 2013 at 5:00 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Do u hose down the engine for any reason?
    Coilpack having a crack could let small amounts of water in and act up till the engine is warm a enoughong enough to evaporate?
    The only time did what ur describing is when it rained hard and I drove hard with the urd intake on and no hydroshield or hydrophobic sock..... Tiny amount of water droplets made it past the filter and would hit the maf sensor and cause the truck to stumble.
    The truck only does it when u change the oil tho right?
    Never at any other time?
  7. Oct 10, 2013 at 6:30 AM
    saltus25
    Graydon
    Angleton,TX
    No i have never hosed the engine compartment down. And the air filter has a metal guard that it sits in. And yes only when i change the oil this happens. And for some reason it only lasts for the first few hundred miles. Its very strange. It almost gives the impression that the fuel pump is dying. Because when i hit the gas it takes a couple seconds for it to register.
  8. Oct 10, 2013 at 6:38 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    A friend and I installed a walbro fuel pump and kit from URD a few weeks ago. When the old has was drained out it didn't loom too bad at 70k, but it was def dirty....
    Oddly tho, the sock filter attached to the OEM fuel pump had METAL shavings in it and 1 chunk was pretty big.
    I supposed u could look at a fuel pump kit with an external fuel filter from dezod or urd.
    At the very least, u will be able to change the filter out easily, and if u ever get the supercharger, this will aid in fuel delivery
  9. Oct 10, 2013 at 6:42 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Do u have the front end on jacks when u change the oil?
    I just woke up so not thinking the clearest..... Would any tank sediment shlosh and effect the flow characteristics once the truck was dropped and started?
    Maybe it is the fuel pump..... I'd expect it to be consistent and even after the oil change tho....
    Specially acting up during stops and takeoffs and grades unless hard on the gas.
    Would u mind kinda retracing ur steps for us?
    What exactly do u include in the oil change?
    Just trying to get more info for others to help, not trying to blame u or anything.... The more info the better.
  10. Oct 10, 2013 at 6:46 AM
    tooter
    Greg
    Los Angeles
    But disconnecting the battery is the only thing I know how to do? :notsure:
    Greg;)
    Hey just an after thought, salt...
    Have you ever sprayed any cleaners on or into your throttle body? Maybe the butterfly is gummed up and is opening too slowly.
  11. Oct 10, 2013 at 6:46 AM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    when you wash the filter do you let it dry first? maybe its a ecu issue?
  12. Oct 10, 2013 at 6:47 AM
    richardbui23
    Richard
    Arlington Texas
    Stacy
    oh no...your not doing the diesel mod are you??
  13. Oct 10, 2013 at 8:16 AM
    saltus25
    Graydon
    Angleton,TX
    So my oil change basically consits of just that. Drain it (sitting on a 4point lift), replace plug, take off filter, clean sealing surfaces with just a dry lint free rag, wet filter gasket with a dab of clean oil, replace filter, replace oil, let sit for 5 min or so and start up. I clean the air filter as needed seperately and yes i let it dry completely before reinstalling.
    Just a wild thought, but would the little drain on the filter housing being clogged have any thing to do with this? I know the crankcase is vented to the intake so i dont know why it would matter.
  14. Oct 10, 2013 at 8:26 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
  15. Oct 10, 2013 at 8:43 AM
    saltus25
    Graydon
    Angleton,TX
    Or.... do you think the oil filter is air bound since its upside down and it just has to run its course to get the airpockets out?
  16. Oct 10, 2013 at 8:45 AM
    saltus25
    Graydon
    Angleton,TX
    It cant be transmission lag. I have the 6speed manual.
  17. Oct 10, 2013 at 9:34 AM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    Ah gotcha ;)
  18. Oct 10, 2013 at 12:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    You never disconnect the battery during your oil change correct?
  19. Oct 10, 2013 at 2:07 PM
    saltus25
    Graydon
    Angleton,TX
    No. Why would i do that?
  20. Oct 10, 2013 at 2:21 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I think Tor is just covering all bases since this is a weird event.
    If he asks, I'm sure its for good reason.... Great guy to have around
