engine light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 96fido96, Apr 21, 2011.
  1. Apr 21, 2011 at 7:50 PM
    96fido96
    96fido96 [OP] Well-Known Member
    ESQ
    ONTARIO CA
    6cyl 4x4 first gen
    I have an 06 PRE RUNNER 4cl manual, my engine light came on I took it to the
    shop, put it in the computer they told me it was just a loose gas cap. I bought a new locking gas cap from local auto parts but light won't go off.
    Is their a reset for the engine light.
    Also how do you reset the maintance light to turn off :p:burnrubber:
  2. Apr 21, 2011 at 7:58 PM
    clarkie152
    clarkie152 Well-Known Member
    MA
    2016 4Runner Trail
    LED light swap, TRD wheels, KO2s, C4Fab lo-pro
    To reset the engine light, you can disconnect your battery for 5 minutes? (I think) and the light will go away.
    Idk about maintenance lights, my 03 let's me decide when I service it.
  3. Feb 3, 2012 at 3:22 PM
    ges
    ges Member
    Greg
    Michigan
    06 Prerunner sport
    I called the shop about the check engine light. They suggested checking the gas cap which turned out to be completely loose. I tightened it but the light is still on. Will it reset by itself? The repair shop suggested it would after it ran an emissions test (and might take 25 starts). Does anyone have experience with this?
  4. Feb 3, 2012 at 3:45 PM
    Tacoma Mike
    Southern Maine
    It needs to see 3 good global trips.
    That being a certain run schedule 3 times with no problems. could take a few days. Needs a combo of city and highway constant speeds for a few miles while completely warming up and cooling off to a cold condition.
    Should go off if the cap was loose. AND also never fill up with the engine running or key on.
  5. Feb 3, 2012 at 6:06 PM
    ges
    ges Member
    Greg
    Michigan
    06 Prerunner sport
    Hey, Thats great news! I'll let you (all) know in a couple a days. Thanks for the quick reply.
  6. Feb 3, 2012 at 8:02 PM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    It is a small evap leak. That doesn't mean it is a gas cap. Anything more then a .80 is excessive for your year. .20 07+. Reset the light, and you need to drive it on the highway for at least 20 min in order for the computer to do all of the tests and determine specs. :)
  7. Feb 3, 2012 at 8:04 PM
    AlaskanTaco
    Anchorage Alaska
    Emission standards say that evap tests can not be performed unless at engine temp, and above 45 mph. You can fill up with the car on ad running and it won't do anything.
  8. Feb 4, 2012 at 4:01 AM
    Tacoma Mike
    Southern Maine
    And your point in quoting me is ???????
  9. Feb 4, 2012 at 9:55 AM
    AlaskanTaco
    Anchorage Alaska
    You can fill up with the car running or key on and the SES light will not come on
  10. Feb 4, 2012 at 10:41 AM
    Tacoma Mike
    Southern Maine
    HEHEHE. yea it has when the conditions are right. but that's ok. Was just checking what you were questioning.
  11. Feb 6, 2012 at 6:25 AM
    ges
    ges Member
    Greg
    Michigan
    06 Prerunner sport
    I drove about 50 miles over the weekend (highway and city). The check engine light did not come on Monday morning when I started her up.
    Thanks.
  12. Feb 6, 2012 at 4:56 PM
    Tacoma Mike
    Southern Maine
    :thumbsup: Good for you..
  13. Feb 6, 2012 at 5:42 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    With the ignition off press and hold the Odometer reset button. Turn the key to Acc(don't start). The Odometer will show 5 flashing zeros that will count down to 4 flashing zeros- 3 flashing zeros, 2 , 1 , none. Then it will show 5 zeros again, at that point release the Odometer reset button. You just reset the Maint Req light for another 5k miles.
