Engine Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DiggerRon, May 25, 2017.
  1. May 25, 2017 at 4:51 PM
    DiggerRon
    DiggerRon [OP] Digger
    Ron
    USA Michigan
    2015 AC 4x4 Tacoma
    Cut 4'' from front mud flaps, Applied Fluid Film to frame for rust preventative,
    Need help my engine light is on again. I have only 17,000 mi. 2015 AC 4x4 auto. About 2mos. ago the light came on I panic. Called service dept. it was time for oil change. they said I might have moved my lever while driving. It just came on again. How can I turn off the light.?
  2. May 25, 2017 at 4:53 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    The check engine light or the maintenance required light?
    wilcam47 likes this.
  3. May 25, 2017 at 4:56 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    yeah big difference. If its a engine light, need the code. If its maintenance light its easy to reset. I believe its the same for tacomas as it was for the 4 runner. but basically hold the odometer but turn the ignition key to on hold till the light goes off(about ten seconds), continue holding the odometer button and turn to off. Start vehicle as normal and the light should be off.
  4. May 25, 2017 at 5:13 PM
    jojotoo
    jojotoo Well-Known Member
    Brandon
    Socal
    2015 DCLB
    Maintenance light is set to come ON 5000 miles after reset.. I think.
  5. May 25, 2017 at 5:14 PM
    DiggerRon
    Ron
    USA Michigan
    2015 AC 4x4 Tacoma
    Check Engine Light Also Trackion concrol Light.
  6. May 25, 2017 at 5:17 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    Get it read out and report back
  7. May 25, 2017 at 5:26 PM
    DiggerRon
    Ron
    USA Michigan
    2015 AC 4x4 Tacoma
    I hope I don't have to get it serviced to get check engine light turn off. Its 40mi. to the service center.
  8. May 25, 2017 at 5:32 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    Go to autozone and they will read the code
  9. May 25, 2017 at 5:41 PM
    DiggerRon
    Ron
    USA Michigan
    2015 AC 4x4 Tacoma
    Thank You
  10. May 25, 2017 at 5:45 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    It is not ALWAYS this, but 9/10 times CEL/TRAC is the gas cap being loose.
    outlawtacoma likes this.
  11. May 25, 2017 at 9:19 PM
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    I understand that if the light is on continuously it's an emission error, gas cap, sensor or wire/ground issue.
    If the engine light is blinking then you stop the truck because there is something seriously wrong. (oil pressure, failed ignition control, excessive knock sensor )
    Maintenance light, you a do a dance with your trip button and key for a while.
  12. May 26, 2017 at 11:57 AM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Flashes upon start up at 4500 miles. Illuminates solid and stays on at 5000
    jojotoo[QUOTED] likes this.
  13. May 26, 2017 at 9:42 PM
    Tdkrum5
    Tdkrum5 New TRD OR P
    Ted
    Oly, Wa/Sun City West AZ.
    2024 TRD OR P
    New ride 2024 TRD OR. Old ride 2014 Icon Stage 5, 265/75/16 BFG AT KO2, Fuel wheels, KMFB sliders,BAMF trilogy skids, Baja Design Squadron Sport WC
    So how do you do this dance?
  14. May 26, 2017 at 9:44 PM
    wilcam47
    Will
    Bourbon state
    I already posted...
  15. May 26, 2017 at 9:50 PM
    Tdkrum5
    Ted
    2024 TRD OR P
    I found it on another thread, Was this you?
    "Turn the ignition “off” Press and hold the Trip Odometer Reset button, and turn the ignition switch to the “On” position. Continue to hold down the Trip Odometer Reset button until “000000” MILES appears on the display and the maintenance light turns off."
  16. Jun 5, 2017 at 6:00 PM
    DiggerRon
    Ron
    USA Michigan
    2015 AC 4x4 Tacoma
    I called my Toyota service center. Using my service record I found the TECT. that work on my truck. He said disconnect the battery for 10 min. reconnect the battery. The Check Engine also the traction control is out. Lesson don't drive with your hand on the shift lever. Thank You TW people.
