Engine noise at start up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SNIPES, Sep 14, 2008.
  1. Sep 14, 2008 at 4:13 PM
    SNIPES
    SNIPES [OP] Well-Known Member
    NY
    04 Access Cab
    Hey guys, I'm brand new on here and have a question regarding my 04 Tacoma. At first start up, if you don't let it idle for 30-60 seconds and begin to drive you will hear what sounds to be a low end knock. At first I was very very concerned, but its been over a year now. The problem has not gotten any worse(knock on wood). Just wondering if there is a common cause of this? I'm actually used to letting it warm up for a minute or so now. The truck is a 4wd 04 Access Cab with a 2.7L and 5spd manual.
    Any help would be appreciated.
    Thanks,
  2. Sep 14, 2008 at 10:21 PM
    Dustin03
    Dustin03 The Cooler King
    Arizona
    Expeditionary vehicle in training.
    Old Man Emu 2.5" lift, brush guard (about to be changed), grey-wire mod, custom bed mounts for 4 jerrycans, custom survival box, maglite mount, KC Dayliters.
    Have you tried to pop the hood and pull the throttle cable? If it makes the noise when you rev the engine in your driveway you can eliminate transmission troubles.
  3. Sep 15, 2008 at 4:21 AM
    SNIPES
    NY
    04 Access Cab
    When I had first heard the noise I actually gave it a lil rev while parked. The noise was still apparent, it only does it for a second or two, almost as if something internaly is not getting oil pressure rite away. I have always kept up with 3K oil changes and have seen no signs of any metal in the oil. I have even went as far as to purchase a oil plug with a magnet. No signs of any metal at all.....
  4. Sep 15, 2008 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your fine. The older 2.7's make noise at start up. No biggey. :)
  5. Sep 15, 2008 at 4:52 PM
    SNIPES
    NY
    04 Access Cab
    I was hoping someone would say that. I have no choice but to run her till she dies anyhow. Hopefully thats much later than sooner.(lol):)
  6. Sep 15, 2008 at 4:58 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    Just wondering what oil filter do you use oem or aftermarket.
  7. Sep 15, 2008 at 4:59 PM
    SNIPES
    NY
    04 Access Cab
    Fram...Would an OEM make a difference?
  8. Sep 15, 2008 at 5:06 PM
    BeefTaco
    Next oil change try an oem they have a check valve in them to prevent oil from draining back to the oil pan frams don't have the valve it could make a difference.
  9. Sep 15, 2008 at 5:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Fram is garbage. Run OEM/Toyota filters.
  10. Sep 15, 2008 at 5:12 PM
    SNIPES
    NY
    04 Access Cab
    Very good news / advice. I have no problem trying an oem. Im due for an oil change next week.
  11. Sep 15, 2008 at 7:29 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    If its any help, my wife's 1987 Celica GTS has done that its whole life-and it still runs like brand new and it dont smoke:)
  12. Sep 16, 2008 at 4:20 AM
    SNIPES
    NY
    04 Access Cab
    Ahhhh yes, this is exactly what I needed to hear....:)
  13. Jan 25, 2010 at 1:34 PM
    trucklover63
    trucklover63 Active Member
    illinois
    04 PreRunner sr5
    its called piston slap,and toyota states this is normal...keeps them from paying for it if it is still under warranty.....
  14. Jan 25, 2010 at 3:01 PM
    SNIPES
    NY
    04 Access Cab
    Yah, it still does it................Been doing it for 40+Thousand miles now, more apparent on colder days.
    The good is that she runs like new with 130K on the clock. No smoke, no oil consumption just an annoying noise at start up.
  15. Jan 27, 2010 at 10:40 PM
    04YodaTaco
    04YodaTaco Well-Known Member
    central NY
    04' Tacoma 4x4 base
    New frame mod. 265/75/16 Duratracs.
    My 2.7 started knocking at start up last winter. First time I almost thought it was a rod knock and almost pissed my pants as it was very pronounced, but it cleared right up and I figured maybe piston slap. Then I searched on here and found out it is common on this engine. Phew!
    Like Snipes mentioned it seems to happen in cold weather. All summer not one knock at start up and then it returned this winter. Also seems to happen more when due for an oil change but this may just be a timing coincidence with the cold weather.
  16. Jan 27, 2010 at 10:50 PM
    04YodaTaco
    central NY
    04' Tacoma 4x4 base
    Just what I wanted to hear. :) I'm just over 50k and looking to get another 100k out of this truck. I have grown attached to it.
  17. Jan 28, 2010 at 7:13 AM
    SNIPES
    NY
    04 Access Cab
    I actually added an oil pan heater that glues to the bottom of the oil pan and plugs into household voltage....lol
    I had tried to find the the engine block coolant heater but the more I thought about it, it just made more sense to have the oil heated. Not to mention, could never find one for the 2.7..........
    You can find the oil pan heaters on ebay for around $40 and are real easy to install. For the most part it elimintated the noise except for those days that the temps are in the low teens.
  18. Jan 28, 2010 at 9:15 AM
    04YodaTaco
    central NY
    04' Tacoma 4x4 base
    $40 isn't much at all, I will look into that. Thanks.
