Engine noise? Whine?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fire Taco Fighter, Mar 5, 2014.
  1. Mar 5, 2014 at 4:16 PM
    Fire Taco Fighter
    Fire Taco Fighter [OP] Well-Known Member
    trd
    I think the best way to describe this noise is...when you have low power steering fluid and turn the steering wheel make that eh eh sound? Its kinda like that I hear it as soon as I start the truck 4.0L. My P/S fluid id full and it doesn't make that sound while turning. To me it seems to be coming from D/S of the engine.
    I am not sure if it's an idler wheel or alt bearing going bad.
    Ant thoughts?
    Thanks
    Otto
  2. Mar 5, 2014 at 4:29 PM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    What year and how many miles I have seen a few idle pulleys make noise start it up and use a long screw driver and put it on the bolt of the idler pulleys and see which one is louder don't get the screw driver caught in the belt tho
  3. Mar 5, 2014 at 4:39 PM
    Fire Taco Fighter
    trd
    2011 65k miles will I hear the whine if I use the lomg screwdriver trick? or just thr rumble of the bearing?
  4. Mar 5, 2014 at 4:49 PM
    wannabetrd
    Zach
    Michigan
    SR5
    With the screwdriver trick and if you find a failed bearing it will be an extremly loud whirring type noise it will sound different from the others
  5. Mar 5, 2014 at 4:56 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    ABS check.
  6. Mar 5, 2014 at 5:02 PM
    Fire Taco Fighter
    trd
    Abs? Noise is while in park. It does get a bit louder when i rev engine
  7. Mar 5, 2014 at 5:04 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Sorry, thought it was on start up only.
  8. Mar 6, 2014 at 1:52 PM
    Fire Taco Fighter
    trd
    FOUND IT!!......Bad Idler pulley....it was the one right by the Alt.
    while I got skid down I'll take out diff drop and change plugs while it's in a warm garage.
  9. Mar 6, 2014 at 5:40 PM
    wannabetrd
    Zach
    Michigan
    SR5
    Glad you found it pretty noticeable wasn't it
  10. Mar 6, 2014 at 6:18 PM
    Fire Taco Fighter
    trd
    Well what I did was buy 2 idlers anda belt. Replaced both idlers andwhile spinning it in my hands i heard andfelt it crunchy
  11. Mar 13, 2014 at 9:21 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
  12. Mar 14, 2014 at 3:22 AM
    Fire Taco Fighter
    trd
    I am keeping the old idlers, press out old bearings and press in new ones so I'll have spares. bearings are cheap.
    good luck Standingcow .let us know how ya make out and which idler it was.
