Engine noise...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyjbaker, Nov 6, 2008.
  1. Nov 6, 2008 at 8:44 AM
    flyjbaker
    flyjbaker [OP] Well-Known Member
    I have an 09 with about 350 miles on it now. Under light acceleration...no noise. Under hard acceleration...sounds normal. BUt under moderate acceleration it sounds like dogshit. I will define moderate acceleration as under fairly heavy load but just shy of making the Auto tranny downshift. It sounds like there is an exhaust leak at the manifold or something. I think there was a TSB somewhere for this???? ANyway, I have heard it from day 1 and figgered I would let the truck break in some before I went to the dealer. ANybody else having this issue?
  2. Nov 6, 2008 at 8:47 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I'm hearing a little bit more from my engine since installing my lift (no relation to acceleration), but I attributed it the fact that I removed the rubber inner fender aprons.
  3. Nov 6, 2008 at 11:30 AM
    wawireguy
    wawireguy Well-Known Member
    What engine do you have? My 2.7L 08 sounds like it has a exhaust leak also in almost the exact same situation as you have described.
  4. Nov 6, 2008 at 11:51 AM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    it might just be the normal taco tick... but there is a link here ya go
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/7107-tsb-list-2005-2008-toyota-tacoma.html
  5. Nov 6, 2008 at 12:35 PM
    flyjbaker
    4l v6.
    Thanks skim.
  6. Nov 6, 2008 at 5:25 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    its common ticking noise mine does it as well during moderate acceleration like u said many here will tell u they havethe same thing mine did it since day one it comes and goes i was told it is just valve noise with the overhead cams. idk tho.
  7. Dec 31, 2008 at 10:35 AM
    wildtrax1
    wildtrax1 Active Member
    GA
    09 4x4 TRD OffRoad
    Mine sounds like you describe too. I drove a couple Tacomas before I bought mine and they also made the noise that sounds like an exhaust leak. I just assumed it is the "taco tick"
  8. Dec 31, 2008 at 10:52 AM
    sonjay
    sonjay Well-Known Member
    If this taco tick you speak of is valve noise, it shouldn't be there. My truck has one valve that sounds bad. It makes a tick, tick. It is not fuel injection noise. If the valves are so loose that they are making noise, it isn't good for the cam, or anything. I'm going to take mine into toyota and get them to adjust the valves. The taco tick I remember from older generation trucks was the power steering pump I believe? Valves should not make much noise.
  9. Mar 10, 2009 at 1:15 AM
    sierra141
    sierra141 Well-Known Member
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    Its just that famous VVT-I if you disconect the sensor by the intake it goes away but it will trigger a check engine light the tik its completly normal
  10. Mar 10, 2009 at 6:59 AM
    allrsdup
    Sahuarita AZ.
    interesting could u give a little explanation on it? im not familiar.
