engine oil grade
Discussion in 'Technical Chat' started by henrilepuf, Oct 1, 2014.
  1. Oct 1, 2014 at 9:13 AM
    henrilepuf
    henrilepuf [OP] Well-Known Member
    henri
    Northwestern Paraguay
    tacoma 2014 4x4 DCLB
    Hi.
    I work with a 2008 Tacoma 4x4.
    I change the engine oil every 5k miles with synthetic 5W30.
    But I wonder if it would not be better to use 15W50 and change every 3k miles, because the truck is working in a very warm climate and severe conditions, lot of dust, very rough roads,...
    Summer here is very long and hot (40 - 45 ° Celsius), and even in the winter the temperature doesn't fall below 10 ° C
    I would appreciate any advice
    Thanks a lot
    All the best
  2. Oct 4, 2014 at 3:49 PM
    Flymaker
    Flymaker Well-Known Member
    Ohio
    SR5 Double Cab
    Bone Stock
    Don't think I would go that high in weight for a couple reason's
    1. Todays motor are of closer tolerance and it just wouldn't be a good fit
    2. The motor in your truck has variable valve timing and while I'm no expert on it operation from what I've read about it , it's proper operation is dependent on oil pressure running 15w oil will raise your oil pressure some
    My owners manual states 5w-30 but 10w-30 can be substituted but should be switched out at next oil change ....I would say stick with the 5w-30 just use a high quality synthetic and you should be fine .....I myself would like to run a heavier grade oil as well but I would only go to a 5w-40 if I did . I would also consider talking to your dealer and see what he has to say ....but that may be pointless hopefully some of the other guys on here that have been into these motors can shed some light on this for you....I use 5w-30 Mobil 1 or Pennzoil Platinum and fell well covered with them.
    dlopan likes this.
  3. Oct 4, 2014 at 5:43 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    Just use water, better for the earth. The folks at toyota don't know what they are talking about.
    Vishnevian likes this.
  4. Oct 4, 2014 at 7:19 PM
    Flymaker
    Ohio
    SR5 Double Cab
    Bone Stock
    Really....why take the time to post something , that is just well fucking stupid ?? The man was asking for advice if you cant contribute why post at all.......just say'in
  5. Oct 4, 2014 at 7:21 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Id stick to 5w30
    I dont know if viscosity would have anything to do with the VVTI?
  6. Oct 4, 2014 at 7:29 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Perfect
    See below, again.
    Agree.
  7. Oct 4, 2014 at 8:11 PM
    Flymaker
    Ohio
    SR5 Double Cab
    Bone Stock
    from what I've read about the Toyota VVT increasing viscosity may be a bad idea , as its operation is dependent on oil pressure . there are supposed to be like weights that swing on the cam and control the timing and there operation is very dependent on oil pressure ......He may be better off with a full synthetic 10w-30 for summer months and run a 5w-30 winter . form what I know about oil and again I'm no expert the closer the 2 numbers are together the better ........so 10w-30 should be the best but they want the 5w for start up.....I use 5wt -30 and every UOA Ive had has come back perfect.....summer or winter....so I just stick with it....If I was him I'd run a 5w-30 all yr and when he's working it harder just shorten the change interval from 5k to 3k ..and again use a good synthetic.
  8. Oct 4, 2014 at 10:02 PM
    G17GUY
    Modesto Ca
    tacoma
    hey whats your opinion on running gear oil in my automatic transmission?
  9. Oct 5, 2014 at 11:53 AM
    henrilepuf
    henri
    OK, thanks.
  10. Oct 16, 2014 at 4:02 AM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I'd stick with the 5-30 as well. Those numbers are plastered all over the owners manuals and on the oil cap for a reason.
    And that's coming from a "thick oil" guy. I've always preferred the thickest oil I can get away with but 5-30 seems to be what Toyota likes. I could see 10-30 in very warm climates with a high mileage engine though. In Paraguay 10-30 might be just fine. A 5-40 might be fine as well but with VVT? You never know.
    Oil weight does mess with VVT systems. I have no idea how VVT works but I have read that they do rely on the proper viscosity of oil to work properly.
  11. Oct 16, 2014 at 1:45 PM
    dunwurguy
    dunwurguy Member
    bill
    Canada
    2011 tacoma 4x4 sr5
    The oil cap on my 2011 Taco states 0w20 only .
  12. Oct 16, 2014 at 1:57 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Inline 4 2.7 L = 0w-20
    V6 4.0 L = 5w-30
    My dealership fucked up once and put 0w-20 in my V6. I was displeased.
  13. Oct 18, 2014 at 4:42 AM
    TRVLR500
    Wyoming
    Yes, I've heard the newer ones have gone to a 0-20 rating. Mine is a 2004. It says 5-30. It'll be 0-10 before long. I might also add that the whole reason they keep going thinner and thinner is for gas mileage. We can use thicker oil but with VVT in so many engines these days it might not be a good idea. I know a guy in Canada who runs 15-40 dino year round in his Caddy's and has no problems at all. His cars are outside as well. Not in a heated garage. That's awful thick for Canadian winters but he has done it for years with no ill effects. He's also a mechanic.
    Personally, i think the thicker oil protects better. If I lived in Florida or AZ or some place else that was real hot in the summer and never got real cold in the winter I'd probably be running a 10-30 or a 5-40 in my Taco.
  14. Nov 7, 2016 at 8:52 AM
    henrilepuf
    henri
    So, coming back 2 years after my first post,
    Since Oct., 2014, running with full synth. 5 W 40.
    Full satisfaction.
