Engine problems - input please (long)
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2toys, May 16, 2009.
  1. May 16, 2009 at 6:45 PM
    2toys
    2toys [OP] Well-Known Member
    Los Angeles
    01 Red Hot Double Taco
    I've been having a problem with a misfire. Been getting 300, 301 and now 303 codes. I've had a Toyota authorized mechanic tell me that it appears to be a bum valve. Compression test showed Cyl#1 120 (iirc) with the others 170-180. (#1 went up to 135 or so with oil added.) The problem is deteriorating and now the engine is stumbling noticeably. I've done the seafoam trick a couple times, and the problem continues.
    Vehicle is 01 with about 130k, I'm the 2nd owner.
    So, it seems my choices are:
    a) valve job and hope for the best ($2k est from above mechanic, 10 hrs work).
    b) replace the head ($500 ebay + labor).
    c) whole new engine (Recycler $1200 rebuilt & installed, price yet to be verified).
    Also note that I have a warrenty (amerigard) on power train, but I will likely only be re-imbursed at best and the work will likely have to be done by dealer.
    I can also likely get a valve job done for much less (the garage around the corner deal). And I might even be able to replace the head myself if I could get a friend or two to lend me a hand (which I get do with some pizza/beer), but I've never ventured beyond replacing a clutch in the past.
    I'd like input on my problem and maybe a choice I've missed.
    Frankly I'm leaning to swap out head.
    PS, I'll likely get another opinion Monday and take it to another Toyota dealer.
  2. May 17, 2009 at 9:47 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Which engine - 3RZ or 5VZ?
    I tend to think you should be good with a lower-priced valve job, assuming you have no other reason to suspect anything worse than a burnt valve. Just my 02 ...
  3. May 17, 2009 at 1:34 PM
    2toys
    Los Angeles
    Sorry, 3rz. Thanks.
  4. May 17, 2009 at 2:34 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Check out how your warranty covers you, is it a reimburse deal or is it a deductible?
  5. May 17, 2009 at 3:09 PM
    2toys
    Los Angeles
    0 deductible, they say they will pay or reimburse. I'm thinking the latter at best...
  6. May 17, 2009 at 3:13 PM
    TRD4x4858
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    That sucks, Being that your from L.A there should be alot of reputable toyota shops that will give you a better quote than the dealer
  7. May 17, 2009 at 3:17 PM
    2toys
    Los Angeles
    Exactly. Best case scenario, I get reimbursed for a minimal amount of work (valve job). Worst case, I don't get reimbursed (due to insurance loop-hole) and pay thru the nose for minimal work when I could have a whole new engine for the same amount of money!!!
