Engine protection while off-roading
Discussion in 'Florida' started by TAC1, Sep 15, 2013.
  1. Oct 15, 2013 at 8:51 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    :spy:
    Yes we do!
    :D
  2. Oct 15, 2013 at 9:11 AM
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    That is true. Plus I have less guilt upgrading something when it breaks vs when it is in perfect working order.
  3. Oct 15, 2013 at 9:24 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    After replacing my entire front end prematurely and having engine issues I now stay out of mud as much as possible. Not so easy when all my trails are below the water table
  4. Oct 15, 2013 at 9:36 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    Damn! Yeah that is not funny. I don't usually get to crazy in water and mud out of fear of that happening. The video and GIF are from my first time wheeling. I plan on having my truck forever so I don't want to destroy it in the first couple years of having it.
  5. Oct 15, 2013 at 9:41 AM
    XXXX
    sKiP
    05 Prius
    Slow down and you will be much better off..... this is my typical speed or a little above what I normally do. If I had another truck there I would of gone slower.
    Photobucket video
  6. Oct 15, 2013 at 1:17 PM
    TAC1
    TAC1 [OP] Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Great suggestions.
    Thanks!
    DAMN!
    Why did you have to replace your front end & what engine issues were you having?
  7. Oct 15, 2013 at 1:26 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Though it may not be far behind, odds are you're going to fry idler pulley bearings before the alternator or starter. Boyd said it.....go slow, and go second. first is cleaner water, but you want someone else to find those 8 foot deep sink holes before you do ;)
    for example, this toasted an idler in half a second....
    and this 20 second swim (that's a long time to sit in water that deep) did absolutely nothing....
  8. Oct 15, 2013 at 8:07 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hey colin,
    Cool boat! Looks like a Tacoma!:D
  9. Oct 15, 2013 at 8:11 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing:
  10. Oct 16, 2013 at 4:00 AM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Yes idler pulleys. I have in the past, on other vehicles, either fully packed the bearings with good grease, or disassembled them, replaced the bearing, but first, cleaned the oem grease and filled with good grease.
    I had read there is a vent on the starter, as time permits, I'm going to see if it's possible to route the vent higher up and externally seal the seams.
    As for the alternator, I have never done this, but it could be much safer to wire a system with single master switch shut down the alternator. This would reduce any loads, but limit the chance to short the internal electrical components. Once clear of the water, and after a minute o let the alternator drain and dry, it could be brought back on line.
    Not saying it would be beer or worse, just presenting an idea.
    Also Peter, if I had plans to drive in that much water, I would seriously consider making some rinse holes in the brake drums and even consider drilling some series of holes in the brake shoe friction surfaces. his would allow the ability to easily rinse the majority of crud out of the rear brakes.
    PK
  11. Oct 16, 2013 at 6:39 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    lol. She's since been christened the SS Pucker Factor.
  12. Oct 16, 2013 at 10:55 AM
    LoadedTaco
    Peter
    Burr Ridge Il
    2012 Red Baja
    I typically don't "plan" on driving through water like that. It was my first trip and I didn't know anything. After those two events happened. I was informed about the risks of driving in water like that. I don't drive fast in water anymore, but I definitely drive in water sometimes.
    Thanks for the tips. I am not sure how or what I would do to go about drilling holes in the drums/shoes. I am mechanically inclined, but pretty inexperienced.
  13. Oct 16, 2013 at 6:51 PM
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thans forthe suggestion PK. Thats a great idea!
  14. Oct 17, 2013 at 3:08 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    Don't hate on 2wd :(
    I did just fine at citrus last year besides getting pulled out 6 tomes by taco hell lol
  15. Oct 17, 2013 at 3:16 AM
    #35
    PMK
    Florida
    10 DCLB TRD Sport
    Yes you drove through water, but if you saw the hump videos from Homestead shot this past weekend, you would see the water I was referring to with Tac1.
    Water overall can be bad, but for DD trucks, that water was pretty deep for minimal oem pretection.
    Don't take it wrong, yours was cool also. You kind of splashed through, these guys were like a war movie when the captain calls out DIVE!, DIVE! DIVE!.
    PK
  16. Oct 17, 2013 at 3:29 AM
    #36
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Last time I changed my air filter, the paper filter was stained with red mud.....not good.
  17. Oct 17, 2013 at 4:01 AM
    #37
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    :rofl:
  18. Oct 17, 2013 at 2:56 PM
    #38
    PMK
    Florida
    10 DCLB TRD Sport
    Damn early morning typos...edited the Do to Don't
    PK
