engine stalls on steep hill off road
Discussion in 'Off-Roading & Trails' started by skynyrd, Mar 29, 2009.
  1. Mar 29, 2009 at 8:27 PM
    skynyrd
    skynyrd [OP] Member
    denver
    08 taco 4x4 quadcab TRD off road 3 inch lift
    3 inch toytech lift 285/75/16 BFG AT KO
    I went off roading today and tried to climb a short but steep hill and I was a little hesitant close to the top and slowed down and suddenly noticed that the engine stalled. My truck is automatic and I went up that hill in 4hi and on D. I tried it again in 4LO and 2 and it stalled again close to the top after i slowed down and stopped, it may have not stalled had I kept going, but I was a little extra careful. Any idea why the truck stalls and how to avoid it?
    Thanks for your valuable advice.
  2. Mar 29, 2009 at 8:30 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    New Bern NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    I'm not sure how the fuel pick up is on these trucks, but maybe you were low on fuel and pushed all of the fuel away from the pick up......?
  3. Mar 29, 2009 at 9:00 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    X2
  4. Mar 29, 2009 at 9:12 PM
    skynyrd
    skynyrd [OP] Member
    denver
    I filled up just before going off road, tank was completely filled up. So it may be something else??
  5. Mar 29, 2009 at 9:21 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    I doubt this would be it but when my car stalls (also an automatic) it's because the transmission can't engage the gear it needs since the clutch sticks and cuts the engine because the car starts rolling and it can't stop itself with its own power.
    Seeing as you were already in gear, I'd wonder if you had a full enough tank of gas first.
  6. Mar 29, 2009 at 9:21 PM
    nighthawk87
    nighthawk87 Well-Known Member
    Take it to the dealer. I went sat. and went up steep hills in 4HI no problem.
  7. Mar 29, 2009 at 9:22 PM
    tacoholic
    East Bay, CA
    Incline was too much? These things only have a certain amount of incline they can take before they call it quits.
  8. Mar 29, 2009 at 9:23 PM
    TacoNut
    Adam
    Denver, Co
    full tank? hmmmmm.....
    did you notice anything different like the engine bogging down before it stalled
  9. Mar 29, 2009 at 9:24 PM
    TacoNut
    Adam
    Denver, Co
    most likely it.... the fuel pump can only supply so much pressure....
    Gravity may be a weak force but it's still a force downward
  10. Mar 29, 2009 at 9:25 PM
    jolayiv
    Jim
    New Bern NC
    Seems you could have put enough load onto the motor that is just said F*** you I quit.:D
  11. Mar 29, 2009 at 9:32 PM
    skynyrd
    skynyrd [OP] Member
    denver
    I noticed no bogging or any other strange noise, also, I did not put much strain on the engine IMHO, the truck appeared to be capable of more. My first guess was not enough fuel for the engine, but tank was full, truck is still under 10k miles and has been to the dealer 4 times for oil change, so it is well taken care off. I will take it to Dealer soon and address that issue.
  12. Mar 29, 2009 at 9:34 PM
    skynyrd
    skynyrd [OP] Member
    denver
    yeah, maybe incline was too much, I have no idea what the degree of incline was.
  13. Mar 29, 2009 at 9:40 PM
    tacoholic
    East Bay, CA
    I mean, that would be my first guess after a full tank. But you can always see what the dealer has to say.
  14. Mar 30, 2009 at 4:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have VSC, hill ascent/descent stuff on your truck?
    An Automatic should never stall going up a hill or driving anywhere for that matter especially if everything is functioning properly and there's plenty of gas.
    Unless some of the VSC - hill descent/ascent features are kicking in and cutting off the ignition for some reason. That's absolutely retarded why it would do that on a hill....that's a safety issue right there.
  15. Mar 30, 2009 at 5:43 PM
    skynyrd
    skynyrd [OP] Member
    denver
    No, I do not have VSC and hill features, I have to 08 model that did not come with those. I agree with you seeing a safety issue here. I also have a 2007 4runner which I will try on that hill next weekend and see if it also stalls. I will definitely take the Taco to the dealer though.
  16. Mar 30, 2009 at 10:03 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    +1. I've been up a couple really steep climbs where all I see is the hood then sky and haven't had any stalling issues. I've even had it floored in reverse pulling another truck out of a ditch back onto the street and the motor gave it it's all in 4Hi Reverse without any tires moving, and eventually the broke free and I just peeled out a little... it never hesitated or stalled, just kind of clutched the trans a bit.
    Try going up it in 4Lo 1st gear, real slow, note how it stalls and at what angle approximately. Nothing should stop you in 4Lo 1st except for a lack of traction.
  17. Apr 4, 2009 at 8:00 PM
    skynyrd
    skynyrd [OP] Member
    denver
    Went to dealer today and they checked if the computer registered some code - nothing. Tried to reproduce the stalling -couldn't. Conclusion: Could not find any explanation for the stalling. So I guess I just take it as it is and try the same hill with the 4 runner and see what happens.
  18. Apr 4, 2009 at 8:02 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    It didnt roll back on that hill did it? itll stall if you roll back a certain amount in the automatics
  19. Apr 4, 2009 at 8:08 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    ^^^^^ I was thinking the same thing.
  20. Apr 4, 2009 at 8:16 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    x2 and in 4LO there is more strain/torque on the motor. You did it just fine in 4HI and you probably slowed down a little befoe the top like you did in 4LO, less torque on the motor so it didn't stall.
