Engine Static through the speakers
Discussion in 'Technical Chat' started by WhosUrBaghdaddy?, Mar 26, 2009.
  1. Mar 26, 2009 at 6:40 PM
    WhosUrBaghdaddy?
    WhosUrBaghdaddy? [OP] Member
    Georgia
    01 PreRunner SR5
    Hello all,
    I recently replaced the spark plugs and wires on my 01 PreRunner Dbl Cab. I travel 45 miles to work everyday, all interstate, and I have noticed now, after changing the plugs and wires, that I hear what sounds like "static" through my speakers when the radio is on. When you let off the gas pedal the noise is more like a popping sound, like the popping of a spark plug sparking. I have also noticed that I am now getting about 45-50 miles less between fuel stops. Any suggestions? Thanks.:confused::help:
  2. Mar 26, 2009 at 6:41 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Did you gap the plugs? Static is usually caused by the alternator.
  3. Mar 26, 2009 at 6:46 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    I was informed NOT to gap the plugs since they were double electrode.
  4. Mar 26, 2009 at 7:08 PM
    dually
    dually Low and slow
    Im not familiar with the double electrode, but im pretty sure it needs to be gapped. Let me do some research..
  5. Mar 26, 2009 at 7:08 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    Was I misinformed?
  6. Mar 26, 2009 at 7:10 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    They were Bosch Platinums
  7. Mar 26, 2009 at 7:11 PM
    dually
    dually Low and slow
    Gapped to .040, both sides.
  8. Mar 26, 2009 at 7:12 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    I'm not familiar with them either. This is the first set I've ever used.
  9. Mar 26, 2009 at 7:13 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    I'll try it tomorrow and see what happens. Thanks.
  10. Mar 27, 2009 at 11:05 AM
    RCBS
    RCBS How long you willing to tolerate this crap??
    Harden your bark, there are storms on the horizon.
    Goodbye 06, Hello 21. TRDORDCSBMT
    Tornado intake, Duralube, Fartcan.
    what brand of wires did you get?
  11. Mar 27, 2009 at 3:45 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Improperly shielded wires would be my first guess.
  12. Mar 27, 2009 at 3:58 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    x2
  13. Mar 28, 2009 at 4:51 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    Wires were from the dealer.
  14. Mar 28, 2009 at 4:53 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    I'm going to try regapping the plugs, as soon as the weather clears up, and see what happens.
  15. May 4, 2011 at 1:18 PM
    ocoinji
    ocoinji New Member
    Jim
    Connecticut
    01 Tacoma xtra cab 4x4
    I have the same problem that you described a while back where you changed the plugs on your toyota and started to notice the speakers picking up a static noise and popping especially on decelleration. Did you ever solve your problem?
    Thanks,
    Jim
  16. May 5, 2011 at 6:53 PM
    WhosUrBaghdaddy?
    Georgia
    01 PreRunner SR5
    I chased that problem for quite a while. I unplugged all my wires and re-installed them, making sure they were tight on the plugs. I finally wound up retorquing the sparkplugs, (I think it was 15 ft-lbs), and then made sure that the coil pack and waste spark wires were tight and properly fitted on the plugs. Problem eliminated. I suspect the plugs weren't grounded properly in the hole and were arcing, thus creating static.
    Hope this helped.
  17. May 6, 2011 at 4:09 AM
    ocoinji
    ocoinji New Member
    Jim
    Connecticut
    Thanks,
    I'll give it a try.
    Jim
  18. May 6, 2011 at 4:52 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Why people feel the need to put overpriced German platinum garbage in their Japanese copper lovin trucks confuses me. How bout some Denso or NGKs oem spec plugs? Guess those mighta done the same thing if not tightened properly too tho.
  19. May 7, 2011 at 7:52 PM
    frog13
    frog13 Well-Known Member
    OEM "electrical stuff", most definetly!.
