Engine stops for no reason
Discussion in '1st Gen. Tacomas (1995-2004)' started by rbbaldwin2, Nov 2, 2011.
  1. Nov 2, 2011 at 9:04 AM
    rbbaldwin2
    rbbaldwin2 [OP] New Member
    California
    2000 Tacoma SR5, 3.4l 4x4
    In the past month, I have had a couple of instances where my truck will just turn off when I come to a stop. I have noticed that my RPM's can be a little erratic at times (revs up and down around 100 -200 rpm). After it shuts off, I just turn the key and it starts right back up. I have cleaned the battery terminals, air cleaner, new injectors ... not too sure what else might cause this. Any help?
  2. Nov 2, 2011 at 9:12 AM
    scocar
    scocar hypotenoper
    Are you getting any codes?
    Sounds like an idle problem. When correct, it should be at 750 RPM. What is yours?
    Once you restart it, does it idle OK, or do you have to give it gas to keep it going?
    It could be as simple as cleaning the MAF sensor inside the intake (after the air cleaner).
    Oh, and welcome to the site!
  3. Nov 2, 2011 at 9:17 AM
    Madjik_Man
    Colorado Front Range
    Might want to look into the throttle position sensor too.
  4. Nov 2, 2011 at 9:28 AM
    scocar
    scocar hypotenoper
  5. Nov 2, 2011 at 11:10 AM
    rbbaldwin2
    California
    I just realized that it may be my MAF ... I recently cleaned and oiled my air filter. I will check the MAF and TPS... Thanks for the help!
  6. Nov 2, 2011 at 1:34 PM
    dark tangent
    dark tangent Well-Known Member
    Madison, WI
    Rigid Dually D2 Amber Driving LEDs mounted on CBI Offroad ditch light brackets.
    Fuel pump perhaps?
  7. Nov 2, 2011 at 1:46 PM
    scocar
    scocar hypotenoper
    Ah! The dreaded oiled air filter. MAF. You should clean your throttle body, too.
  8. Nov 2, 2011 at 1:53 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I would have thought IAC valve before he mentioned the recent oiling he's done.
