Engine stumbles on inclines
Discussion in '1st Gen. Tacomas (1995-2004)' started by yotatomy, Oct 7, 2010.
  1. Oct 7, 2010 at 2:07 PM
    yotatomy
    yotatomy [OP] Active Member
    Tom
    Washington
    My 2002 V6 prerunner tends to hesitate on minor inclines. This condition occurs when the engine is warm and the throttle position is steady and I am on slight incline at about 55 MPH. It is intermittent and only does this when going up a slight incline. Plenty of fuel in the tank and no heavy loads in the bed. Any one experience any thing similar?
  2. Oct 7, 2010 at 4:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch Diode Dynanics SS3 Sport Selective Yellow Fog Lights 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Doug Thorley Headers Magnaflow 18" Muffler w/upstream CAT delete 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Is it an auto? Is it downshifting?
  3. Oct 7, 2010 at 4:44 PM
    Tankoma04
    Tankoma04 Member
    SoCal
    04 PreRunner
    3.5 inch Fabtech front lift & 2.5 inch lift rear
    same thing happens to me...but ive been under the impression its just the heavy ass tires...
  4. Oct 7, 2010 at 5:08 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Whens the last time u did a tune up?
  5. Oct 8, 2010 at 10:51 AM
    yotatomy
    Tom
    Washington
    tuned up about 2400 miles ago. Stock tires and yes it is a automatic. The RPM remain steady and it is not trying to down shift.
  6. Oct 8, 2010 at 10:52 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    is it just the sound of more load on your engine?
  7. Oct 8, 2010 at 10:55 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    i had something similar on my 96. ended up being a set of bad wires not giving enough juice to the plugs. my mechanic, who knew I did my own wrenching, took one listen to it, moved the throttle wire in the bay and said yup, bad wires. just something to think about.
  8. Oct 8, 2010 at 1:53 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    That's what I was thinkin too...incorrect spark plug gaps or bad wires...what all did u do for a tune up???
