Engine turns on then dies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rondog, Feb 18, 2013.
  1. Feb 18, 2013 at 10:52 AM
    BDJ
    BDJ Well-Known Member
    Brandon
    West Monroe
    2012 TRD OR 4x4 DBL Cab MGM
    Yes I had to replace the computer, but it was under warranty so it just cost me $100 out of pocket. The total bill was around $1800 if I remember correctly.
  2. Feb 18, 2013 at 10:55 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Jeez!!! Yeah I'm not surprised if it cost that much to fix. Hopefully the OP still has his under warranty if thats the issue.
  3. Feb 18, 2013 at 11:00 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x on 5100s / LR UCA Wheelers 3 leaf progreaaive AAL 275/70/17 KO 2's on 17" fuel Hostage no rubbing
    i guess im really no help here since i drive a 1st gen but my truck did the same thing and it was the crank shaft sensor...after a few times of starting and hard idling then dieing it just wouldnt start at all...
  4. Feb 18, 2013 at 11:04 AM
    rondog
    rondog [OP] Well-Known Member
    Ronnie
    Escondido/San Diego
    Def out out of warranty lol..mine would start every time it's just that the engine would die after a few seconds. I've turned it on ad off a few times with no problems now. It's idling fine. Only thing is the check engine lights still on. I'll be checking it after work with a scan tool
  5. Feb 18, 2013 at 11:14 AM
    rondog
    Ronnie
    Escondido/San Diego
    so drove it around the block a bit more and the check engine light isn't on anymore...dafuq? I'm still going to throw an obd scanner on it after work
  6. Feb 18, 2013 at 12:27 PM
    rondog
    Ronnie
    Escondido/San Diego
    So I successfully made it to work..about 15 miles worth of street driving. Had no issues the whole way, thankfully.
    One thing I did notice....for the past year or so when I would use anything with an electric motor (like the fan, the windows etc) my idle would drop and the truck would shake. It isn't doing that anymore!
    The idle goes back up to compensate for the load again. I bought the throttle body a while ago and never replaced it with the new one so maybe it has been going bad and it had just finally died? I'd like to hope anyway.
    I'll post an update with the OBD codes later
  7. Feb 18, 2013 at 1:26 PM
    99TacoDriver
    South Louisiana
    thats strange
  8. Feb 18, 2013 at 2:15 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Interestingly strange. It does still sound like an electrical issue though, I still am suspect of the ground to the engine block.
  9. Feb 18, 2013 at 2:48 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah let us know what code it is throwing.
  10. Feb 18, 2013 at 3:01 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Why did it cost you $100 if it was under warranty?
    You have a 2012... it should still be under 3/36 and there should not be any "Toyotacare" deductibles.
  11. Feb 18, 2013 at 4:48 PM
    rondog
    Ronnie
    Escondido/San Diego
    I'll post em in a few hours. Regarding the CE light being on, I bet that came on when I tried to start the engine with the MAF unplugged as well as the throttle body...which would also be why it went away
  12. Feb 18, 2013 at 5:10 PM
    BamaToy1997
    Bill
    Navarre, FL
    Well yeah, if you tried to start it with those disconnected, you will set a light.
  13. Feb 18, 2013 at 10:08 PM
    rondog
    Ronnie
    Escondido/San Diego
    So the scan gave back two codes
    P0102
    P0113
    Which are MAF sensor codes..probably because it was unplugged. Truck is still running fine. We'll see tomorrow morning. Maybe, if I'm lucky, it was a bad throttle body and I got lucky for having a spare
  14. Feb 18, 2013 at 10:15 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah hopefully your good to go know.
  15. Feb 19, 2013 at 11:14 AM
    #35
    rondog
    Ronnie
    Escondido/San Diego
    turned on fine this morning again. It was either a dirty MAF or bad throttle body. MAF has been cleaned and throttle body replaced. My guess is the computer in the truck hadn't recognized one or the other changes.
  16. Feb 19, 2013 at 11:57 AM
    #36
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Good to hear.
  17. Feb 19, 2013 at 12:03 PM
    #37
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I know for a fact, when you unplug the battery for more than a few minutes, and then reinstall and turn the truck on, it'll die the first time you try to start. Then the second or third time, the RPM will idle above 1000 in drive and around 1500 in park. It's just the computer remapping the A/F mixture, which has a lot to do with the MAF. I'm guessing unplugging the MAF sensor also resets this.
    Like others have said, I'd check all the grounds for corrosion. Also, try cleaning off the terminals on the battery and where the engine ground to the frame.
  18. Feb 19, 2013 at 12:06 PM
    #38
    rondog
    Ronnie
    Escondido/San Diego
    I actually did this a few months ago. I am almost certain this was the MAF or throttle body. I am looking into a new cold air intake. I have the K&N which ehh..whatever, I cant pass smog now. I never really noticed any gains, just a loss of mpg :D
    Who knows, maybe back to stock is the best idea.
  19. Feb 19, 2013 at 3:26 PM
    #39
    BamaToy1997
    Bill
    Navarre, FL
    That is not 100% on all Tacoma trucks. I have had several in my shop, from 1st gen and 2nd gen, that started right up and idled fine, even after the battery had been disconnected for anywhere from 5 minutes to 5 hours.
  20. Feb 19, 2013 at 3:32 PM
    #40
    The Traveler
    SoCal
    I wonder what the variation is? I can understand 1st gens being different, but why would only some 2nd gens do that and not others?
