Engine vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JSTACO, Nov 30, 2011.
  1. Nov 30, 2011 at 8:45 PM
    JSTACO
    JSTACO [OP] New Member
    TRD
    I own a 2012 TRD V6 Auto. I am getting vibration at idle in park. Vibration (feels like a rumble) comes and goes as you sit park. Any one have thougts or know a fix? Should I be concerned?
  2. Apr 21, 2012 at 11:34 AM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    Bump. Me too. WTF? my FJ had no issues. Anyone?
  3. Apr 21, 2012 at 2:14 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's, Pioner AVH-2300NEX w/backup camera, SCT X4 Tuner.
    Is your A/C running when this happens?
  4. Apr 21, 2012 at 2:59 PM
    CantSitStill
    FTR
    CNY
    Does it either on or off. Not RPM sensitive either.
  5. May 8, 2012 at 1:02 PM
    Gaffer
    Gaffer New Member
    Gaffer
    Coastal Maine
    4x4 work truck
    My 2012 Tacoma has a 2.7L 4 cyl and it vibrates between 1500 and 1700 rpm. Has been back to the dealer and they say nothing wrong. Anyone have contact info for a Toyota technical expert that may be willing to help. It is my first Toyota and it will be my last if this goes on forever.
  6. May 9, 2012 at 7:41 AM
    JSTACO
    TRD
    I was told by the dealer to watch the issue and if the check engine light comes on to come in. If you find out what the problem is, please post it so I can force my dealer to fix the issue.
    Also, the vibration no longer just happens in park. It occurs whenever I am not moving. It could be in park or drive at a stop light.
  7. May 9, 2012 at 7:44 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Mine did that but one of my motor mount bolts was broken and barely on this but you have a 2012 should be good
  8. May 9, 2012 at 12:08 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    OP I have had that problem for a while too. If I use a gas treatment it goes away for a while so I think I might have to change my filter but you have a 2012 so your filter should be good.
  9. May 9, 2012 at 4:16 PM
    CantSitStill
    FTR
    CNY
    Running higher octane (93)and Startron and it went away. Dropped the Startron this past tank and still no vibration yet. Filling tomorrow with 89--- will see what happens.
  10. May 9, 2012 at 7:50 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Mine will do that if I drive conservatively for a while. It's always the same symptoms - the throttle gets dampened, the engine ticks a little louder when it's cold, and it has that bit of a recurring tunk feeling that just barely can be felt at idle. Kinda reminds me of the way the idle of an old 8N feels, just much more subtle.
    If I get on it a couple times it will behave normally for a while. I chalk it up to carbon buildup.
    It was much worse before the engine computer was done with all its learning, which seemed to take about a thousand miles before everything ran consistently.
