Engine Weight
Discussion in 'Technical Chat' started by centerwall, Jan 19, 2012.
  1. Jan 19, 2012 at 6:28 AM
    centerwall
    centerwall [OP] Active Member
    Bruce
    Elk River, MN
    2017 White Tacoma SR5 Double cab 5' box
    ARB front bumper textured black finish, Old Man Emu suspension, scooped hood, BakFlip cover
    I need to find out the weight of my engine so I can match sandbag weight in the back. I have a 2007 double cab prerunner. Thank You
  2. Jan 19, 2012 at 6:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Engine weight is irrelevant, you don't need to match it for the bed weight. I just throw about 270 lbs of steel weights in the front of the bed. Good tires make a huge difference also.
  3. Jan 19, 2012 at 6:34 AM
    Camshaft
    Camshaft Active Member
    Camshaft
    Saskatchewan
    Tacoma SR5 2.7 2wd
    GROM ipod, usb, 3.5mm input
    2x 60lb bags of sand in the nook between the front of the box and the wheel wells made a world of difference for me. I also run my rear tires at about 26 psi
  4. Jan 19, 2012 at 6:35 AM
    centerwall
    Bruce
    Elk River, MN
    Thank you, that's good to know. I have about 800 lbs. of bags back there right now.
  5. Jan 19, 2012 at 6:37 AM
    Pugga
    Massachusetts
    In the words of Mr. 4x2, wholy sheeit! :eek: That's a lot of weight to be toting every day just for extra traction. 300 should be more than enough, if it's not you need better tires and a lighter foot! Keep the weight over or in front of the rear axle, if you put it behind the rear axle, you're just unweighting the front end. It's more important to steer and stop.
  6. Jan 19, 2012 at 6:41 AM
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    Good-bye leaf pack
    :wave:
  7. Jan 20, 2012 at 10:12 AM
    Camshaft
    Camshaft
    Saskatchewan
    Tacoma SR5 2.7 2wd
    LOL agreed! Could be time to purchase the 4x4 model if that's the case
