Engine Whining - Stealarship cost for alternator, idler pulley, belt...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NiceGuyEddie, Jul 26, 2022.
  1. Jul 26, 2022 at 9:23 AM
    NiceGuyEddie
    NiceGuyEddie [OP] Well-Known Member
    Chino, SoCal
    none yet
    I've been through the threads about the whining from the engine bay - could be idler pulley, alternator, etc. 200K on the 2010 truck so this is scheduled maintenance.
    I'm busy with work and a baby twins at home, so for the first time in my entire life I'm considering going to the stealership. It's also ripping hot where I live right now.
    I don't trust Jonny Mechanic down the street. Any ideas what the dealerships charge for alternator, pulley(s), belt?
    SR-71A likes this.
  2. Jul 26, 2022 at 9:44 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I get that you are busy, But take the 20 min to pull the serpentine belt on a cold truck and spin the idlers and alt by hand rather than having a dealership just BEND you over. Also what kind of noise is it? Got video? my diode pack on my alternator had one set that went bad and created a wining noise even though the alternator bearings and idler bearings were all perfectly smooth - you can determine if its this by on a running truck with it making the noise unplug the small 4 pin connector on the alternator.
    BassAckwards and Raylo like this.
  3. Jul 26, 2022 at 9:45 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Call the dealer and ask?
  4. Jul 26, 2022 at 9:50 AM
    NiceGuyEddie
    Chino, SoCal
    none yet
    I'd rather not call the dealer and ask the price, I prefer to have my ammo ready first.
    I'll have to look up "diode pack" - never heard of it.
  5. Jul 26, 2022 at 9:54 AM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    How long has it been since you've done your serpentine belt? I could've sworn that I had a worn idler pulley on my previous 2006 Taco, but it was just the serpentine belt. They don't last too terribly long on these trucks before they start squeaking in the cold - I think my last one first did it at around 40k-50k in and I replaced it after it was on for ~85k.
    Granted, that noise is more of a squeaking/squealing than a whine, so just food for thought.
  6. Jul 26, 2022 at 9:58 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  7. Jul 26, 2022 at 9:59 AM
    NiceGuyEddie
    Chino, SoCal
    none yet
    I've never replaced ANYTHING on the truck! All original. I've changed all the fluids obsessively. Engine bay is perfectly clean with no leaks whatsoever. It's weird that this noise came all-of-a-sudden but I guess that's the way it is.
    I'm currently struggling with even the time to remove my skid plate and catalytic converter, but I'd at least like to try to remove the belt(s) and spin everything.
  8. Jul 26, 2022 at 10:10 AM
    nd4spdbh
    SoCal
    Get a video of the whine and post it. We are hear to help but cant do much without at least a walk around while its doing it.
    I would try pulling the plug on the alternator while its running, that will give you a real good idea if its electrical from the alt, or mechanical bearing noise somewhere else. Then pull the belt and spin things.
  9. Jul 26, 2022 at 10:49 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Actually, finding a good 'Jonny Mechanic' is where I would be headed with that repair. If you have the NextDoor app, ask on that for a good shop for your area. Generally, you will get a few good suggestions and you can investigate from there. I am the other way around, my local dealership is FULL of technicians who do not care and are just waiting for the 5PM bell. A couple of visits for a couple of recalls and work requests confirmed that painfully for me. Luckily, I found a competent and caring local shop.
    Superdave1.0 likes this.
  10. Jul 26, 2022 at 10:52 AM
    NiceGuyEddie
    Chino, SoCal
    none yet
    https://youtu.be/37U4ChjHsmw
    Well I'll be a monkey's uncle. Disconnecting the green tab on the alternator indeed made the noise go away. I messed up the video and I don't have a video of it running.
    OK so what's next?
  11. Jul 26, 2022 at 11:20 AM
    nd4spdbh
    SoCal
    So the noise 100% went away when you unplugged the 4 pin green plug? The noise in the video definitely sounds like the noise I had. If so Then its your alternator diode pack that has a bad diode. Like linked above you can go through the process to rebuild it or get a good denso remand unit from Napa / rock auto (for way less)
    https://www.napaonline.com/en/p/DEN2101084?impressionRank=9
    https://www.rockauto.com/en/moreinfo.php?pk=11195433&cc=3015100&pt=2412&jsn=854&_nck=ZExt1ysfqhqWnq+EvUNdS3Txyey60IDtnjPWF5UU9J0BWQv7pvqZbkEUk86+AYIhylPKrF7bIqGdrWKuP14r+XskRz67wIgr+FnKbxeYP4QC2nDXN+TTQvUF5FZczsQ25fCJ5YbJxwGLu+Id2PWCWnjA7GiPh9ARr95Di+9TAEyYHfJFweULMAEsCz+sni59eoC0kNPC2YeGS5c+DQgIjq3Qv5eiyYWSGFRzASzykAw/dKJW8bTMKb0VawEeCf0Vn5Fbo3F3Aqsp1s+3+M0duwF+vA5gia7Q1O3wDfSrlOV66sfSA3sEewpQiaFdEyIiqyGFX4jhUT69SUR9xRn9KymR9DkXXqlH
    I would also consider at the same time, replacing the serpentine belt with an OEM one. Your idler pulleys are likely fine, you could loosen the serpentine belt before buying parts to spin them by hand to see what they feel like, but with how clean your engine bay looks I doubt they have seen a hard life full of contaminates from off roading or bad weather.
    SR-71A and BassAckwards like this.
  12. Jul 26, 2022 at 11:28 AM
    Clearwater Bill
    Billy
    Largo Florida
    Another option on the alternator is to have it rebuilt locally if you have a historically reputable electrical shop in your community.
    The one I use here would gladly take a new belt I brought them and install it for me while putting things back together.
    I've found it cheaper to have this done, parts and labor, than a big box reman purchase and my own labor.
    Tip. At 200k, your truck needs more attention than lubricants.
    cruxofthebisquit and Sandman614 like this.
  13. Jul 26, 2022 at 11:47 AM
    NiceGuyEddie
    Chino, SoCal
    none yet
    Yes, to my surprise the problem is 100% gone after disconnecting the green tab.
    It looks like I'm doing the alternator and serpentine belt while I'm at it. I will certainly check the idler pulleys.
    I've seen NO off-roading or bad weather and as you can see the engine bay is quite clean. It could use a quick foam bath, though.
    Yes, at 200K I have a laundry list of scheduled maintenance, one of which was replace the belts and rubber hoses.
    I am very surprised this noise would come all-of-a-sudden and disconnecting the alternator stops the problem. Why is this? Something inside stops spinning?
    And how much longer to I have until the whole thing goes kaput?
  14. Jul 26, 2022 at 12:07 PM
    nd4spdbh
    SoCal
    From my alternator thread
    As far as other maintenance, just a general once over on the truck, I wouldnt bother with rubber hoses unless you see signs of cracking. Spark plugs if its time, MAF cleaning, Air filter, coolant and greasing up the U joints of the driveline are other quick and easy ones that will keep things going for a long time.
    SR-71A likes this.
  15. Jul 26, 2022 at 12:10 PM
    NiceGuyEddie
    Chino, SoCal
    none yet
    OK I read the "phases" thing, I'm an engineer so I understand that part, but I don't understand the noise itself. (I guess I'm not a good engineer o_O)
    Should I lay off the a/c until it's fixed? I just need to go to/fro work & the dealership, about 11 miles each leg no freeway.
  16. Jul 26, 2022 at 12:14 PM
    nd4spdbh
    SoCal
    AC wont make a difference with the issue with the alternator. Again I wouldnt bother with the dealership, they are going to charge you an arm and a leg (probably over double) for the same remand alternator and labor is going to be through the roof.
    You can drive on it some, keep an eye on the battery light but realistically get it fixed asap.
    Sandman614 likes this.
  17. Jul 26, 2022 at 12:22 PM
    agmason
    agmason Well-Known Member
    Austin, Texas
    2007 Prerunner 4dr LWB
    Agreed. Good advice I had similar issues with my '07 pre runner and swapped the alternator back in 2021 with a reman denso unit from https://www.rockauto.com/.
  18. Jul 26, 2022 at 12:23 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    301k miles now on my alternator that I rebuilt and not an issue out of the bearings or other parts. Like everything YMMV and I have a spare alternator sitting on the shelf.
    nd4spdbh[QUOTED] likes this.
  19. Jul 26, 2022 at 12:51 PM
    nd4spdbh
    SoCal
    Oh yeah no doubt a properly rebuilt alt will go a long time, they are pretty darned simple. Also having the spare on the shelf makes the one in use behave for longer, proven fact.
    Sandman614[QUOTED] likes this.
  20. Jul 26, 2022 at 1:25 PM
    NiceGuyEddie
    Chino, SoCal
    none yet
    UPDATE:
    Just so happens that the alignment shop that I use near my work also has a highly-recommended mechanic.
    It's going to be "only" two hours labor for alternator, serpentine belt, and all pulleys. Not too bad. Parts prices are as you would expect. Since my thread is about the stealership price I will gladly come back and update with the total price from the mechanic.
