Environmental Control Lights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wilky10, Oct 7, 2010.
  1. Oct 7, 2010 at 4:03 PM
    wilky10
    wilky10 [OP] Active Member
    Tucson
    06 DC TRD 4x4
    I have a 2006 DC that my control lights for my air/ac are intermittent. Has anyone seen this before? It started with the position selector first, now the fan speed light isn't working and the position selector is. When I tap it, the lights will illuminate sometime. Is there an easy fix for this. I haven't taken the panel apart yet, so I am unfamiliar as to what is behind there.
    Thank You in advance,
    Nick
  2. Oct 7, 2010 at 7:31 PM
    m3zy6
    m3zy6 Well-Known Member
    Roanoke, VA
    07 AC TRDOR 4x4 6spd
    The backlight is actually 2 small bulbs that screw into the back. Sounds like one of them needs to be reseated or replaced. You should be able to pop out the whole assembly from the dash and check it in less than a minute.
