Error code meanings
Discussion in '1st Gen. Tacomas (1995-2004)' started by Racemx904, Aug 20, 2018.
  1. Aug 20, 2018 at 3:35 PM
    Racemx904
    Racemx904 [OP] Active Member
    Ron
    2000 green Tacoma xtracab
    2000 Tacoma 2.7 auto 4wd
    Sputters on takeoff every now and then....
    Errors codes
    P0120
    P0420
    P1310
    Running Board Man likes this.
  2. Aug 20, 2018 at 4:28 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    P0120 - Throttle position sensor (TPS) malfunction
    P0420 - catalytic converter efficiency below threshold
    p1310 - igniter circuit malfunction #3
    so, before starting to throw parts and money at it, can you describe if you have any particular symptoms, other than sputtering? Do you have rough idle, or anything like that?
  3. Aug 20, 2018 at 4:32 PM
    Racemx904
    Ron
    Every now and then it sputters when taking off.... warmed up only....
  4. Aug 20, 2018 at 4:39 PM
    onakat
    Canada
    2000 indestructaco!
    hmm, all these codes can be related to a misfire... and the fact it's sputtering could indicate that too
    first, let's talk about the sparkplugs. When were they last changed? And what is your mileage?
  5. Aug 20, 2018 at 4:40 PM
    Racemx904
    Ron
    157k..... just bought truck he changed coils
  6. Aug 20, 2018 at 4:41 PM
    onakat
    Canada
    2000 indestructaco!
    were the plugs changed as well? if you dont know, I'd take a look at them
    p0130 means there is problem with coil on cylinder #3.
    coils can be changed, but some people put their worn out plugs back in there....
  7. Aug 20, 2018 at 4:49 PM
    Racemx904
    Ron
    I’ll go grab plugs tomorrow.... I’m sure he didn’t.... any plugs work better than others
  8. Aug 20, 2018 at 5:10 PM
    onakat
    Canada
    2000 indestructaco!
    NGK or Denso. Don't get anything else
    There's three types of plugs. They are all the same, but the difference is in how long they last. Don't go believe stuff like any particular type will give you more HP, that's bullshit. Though, fresh sparkplugs will improve your MPG if you have old worn out plugs
    Copper is the cheapest but they also have the shortest lifespan. They must be replaced at about 30k miles intervals
    Platinum have a longer lifespan, needing to be replaced at about 100k miles
    Iridium are the most expensive of the bunch, but they can last for 120k+ miles
    I did put iridium plugs in my truck (I have the 2.7l, like you) and it's running great.
    Also, before putting them in, check if the gap is good. They are supposed to come pre-gapped, but I prefer to check, just in case. The gap must be 0.044"
    License2Ill likes this.
  9. Aug 20, 2018 at 5:33 PM
    Racemx904
    Ron
    Ya I try to stick to Ngk unless a Ford...
    Thank you
  10. Aug 20, 2018 at 9:20 PM
    onakat
    Canada
    2000 indestructaco!
    while you'll be in there, check and test your coils packs to see if there is something wrong with them, especially cylinder #3. Take a look at the wiring too
    To erase your error codes, if you do not have a scan tool, unplug both terminals of the battery for 15 min.
    keep us updated on if your error codes come back
  11. Aug 22, 2018 at 3:02 PM
    Racemx904
    Ron
    I have a scan tool....
    Plugs, wires, coils all new
  12. Aug 23, 2018 at 6:18 PM
    Racemx904
    Ron
    Today drove good..... got to gym, played ball for an hour and came out to this.....
    Start, die, start die....
    Hold it wfo and soon as you let off it dies..... finally held it there for a minute then boom went back to fine....
    Wtf?
  13. Aug 23, 2018 at 7:16 PM
    stomachbuzz
    stomachbuzz Well-Known Member
    Silver Spring, MD
    2005 V6 6spd!
    Only the TPS and ignition coil would giving you running issues.
    You can ignore P0420 for now.
    Did you clear them? and if so, what came back?
  14. Aug 24, 2018 at 2:16 AM
    Racemx904
    Ron
    420 & 1310 came back....
    Coils are new I might go pick up tps tomorrow
  15. Aug 24, 2018 at 7:32 PM
    onakat
    Canada
    2000 indestructaco!
    yes, probably TPS then. Looks like it's acting up
    especially since it did pop you a code related to it before (P0120)
  16. Aug 29, 2018 at 1:34 PM
    Racemx904
    Ron
    Tried unplugging tps..... didn’t help and made it worse because it don’t downshift when you punch it....
    Does it from a stop to about 35mph
    Any other ideas? Mas? Air leak?
  17. Aug 30, 2018 at 9:58 AM
    onakat
    Canada
    2000 indestructaco!
    if you remove the TPS, of course the car will run bad. TPS is essential part of the system, as it allows the car to regulate the fuel. The car can't know you are at idle or holding the the pedal to the floor if it does not get the signal from the TPS
    if you want to try something else, what about cleaning the mass aiflow sensor, the throttle body and the idle valve? pretty easy to do
    Then if it doesn't get better, get another TPS (it's like 50 bucks...). They sometimes tend to act up on old cars, but if you want to make sure it is bad, you can still test it (lots of how to videos on youtube)
  18. Aug 30, 2018 at 10:00 AM
    eon_blue
    eon_blue Most Improved Member
    P0420 usually means a leak in the exhaust system or a bad catalytic converter...if you have a cat that's plugged up bad it will really effect your truck's performance. Can also indicate a bad o2 sensor if I'm not mistaken.
    I had a P0420 and had to replace my front cat, truck ran much better afterward. Don't go doing that though until you confirm it's good or bad.
  19. Aug 30, 2018 at 10:09 AM
    onakat
    Canada
    2000 indestructaco!
    true, but he had a few other codes as well, related to TPS and ignition coil issues. That why I think it is something related to the fuel delivery components (can cause p0420 as well)
    btw, how did you know the cat was bad? how did you test it?
    I'm chasing p0420 issues as well... but no symptoms
  20. Aug 30, 2018 at 10:10 AM
    eon_blue
    I gave up and took it into Toyota, lol. They ran their emissions test on it and concluded the front cat was bad...I wasn't surprised because I'm supercharged and my truck had lean issues for a long time (which is known to kill the cats).
    onakat[QUOTED] likes this.
