evap. cannister AGAIN!
Discussion in '4 Cylinder' started by mgahan, Aug 6, 2012.
  1. Aug 6, 2012 at 3:01 AM
    mgahan
    mgahan [OP] New Member
    2010 tacoma access cab
    Having to replace my 4th evap. cannister. Obviously there is underlying problem for my 2010 4 cyl. tacoma. Any ideas?:confused:
  2. Aug 6, 2012 at 5:12 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    do you top off all the way to the brim. You could be getting it full of fuel.
  3. Aug 7, 2012 at 11:29 AM
    mgahan
    no. i'm aware of that problem
  4. Aug 7, 2012 at 12:52 PM
    Tacoma Mike
    Southern Maine
    What codes are being set ??
  5. Aug 8, 2012 at 3:01 AM
    mgahan
    don't know the exact code # but if you think you have an idea I'll get them for you. They changed the cannister (4th) again but like I said, has to be some underlying problem. They treat the symptom but not the cause. Thanks
  6. Aug 8, 2012 at 6:44 AM
    Tacoma Mike
    Southern Maine
    Without the codes and more background no one can begin to help u.
    I agree with your thinking that something else is going on.
    The more info you post the better.....
    Evap codes are a PITA. They will make u pull your hair out.
    Not sure we can help but info will help every one.
  7. Aug 9, 2012 at 3:07 AM
    mgahan
    After 132 miles the check engine light is on again( so much for the new cannister). So today toyota is gonna find out that I too can be a PITA, a real big one.
  8. Aug 9, 2012 at 3:11 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    We've been having an issue with our hyundais lately at our shop. Some of ours have 2 canisters. What we've seen is a spider web issue. The webs get sucked into the tube and pulled into the first canister. After changing out the first canister, the code returns and the second canister is bad after the customer drives off. We end up replacing that one as well. Not sure if this is helpful to you or not. Spiders love getting in there, just like a gas grill and their webs can cause some big time problems.
    We've also seen where a purge valve issue is diagnosed from one of the canisters, but after changing it out the code returns and it's actually a connector issue. We've seen corrosion or simply a bad connector to the purge valve that shows the valve inop even after it has been replaced.
