Excessive Pinging
Discussion in '1st Gen. Tacomas (1995-2004)' started by MyTaco, Oct 19, 2008.
  1. Oct 19, 2008 at 3:19 PM
    MyTaco
    MyTaco [OP] Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Have a 94 p/u with a 22r that pings like a SOB. Timing is correct, no check engine light issues. Do these have a knock sensor and if so where would it be?
  2. Oct 19, 2008 at 3:43 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I'm guessing that with the age of that beauty and the work it has to do-you have carbon buildup on the pistons which can possibly raise the compression ratio enough to cause detonation. do a search on "Seafoam" I read that stuff works the ping right out! I don't know if that engine had knock sensors yet but Chris 4x4 will be along shortly to button up an answer for you:)
  3. Oct 19, 2008 at 3:49 PM
    MyTaco
    Az
    08 Prerunner
    Lol, yea it's my beater truck with 208k probably up to 11:1 comp but runs fantastic except for pinging like hell...but it stops pinging when I run 100 Octane Trick Unleaded! I'll check out "Seafoam"...thanks
  4. Oct 19, 2008 at 3:55 PM
    Ridgerunner
    Frank
    San Francisco
    Sounds like a plan buddy:) if you can clean out a good lot of that carbon and bring down that compression the ol' faithful wil be purring again!!!
  5. Oct 19, 2008 at 4:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ridgerunner is correct. If the timeing is set right, pull your plugs and give them a look-see. Then if you can do a pressure test. Odds are you just need to run some sea foam thru it. First, make sure your timeing is set correct. Also, the 94's dont have knock sensors. :)
  6. Oct 19, 2008 at 8:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    seafoam will do a great job of cleaning out all the carbon. also, you may want to run a bottle of techron thru the gas tank to clean the injectors and all, as that will help too.
  7. Oct 19, 2008 at 8:18 PM
    pittim
    pittim mittip backwards
    Pittsburghish
    Mk7 Oil Burner
    Permanent CEL
    When you guys run Seafoam, do you only do 1/3 of the bottle into the brake booster, or do you do the 3 differnt parts (brake booster, fuel, and some other part)?
  8. Oct 19, 2008 at 8:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i do mine, i'll usually do half in thu the booster, or sometimes a 3rd thru booster, then rest in the gas tank. i dont add it to my oil. half thru the booster worked for me when i first got my truck,since it was running rough, so i did a couple of applications, and it definitely helped with the way the truck ran.
  9. Oct 19, 2008 at 8:44 PM
    MyTaco
    Az
    08 Prerunner
    Thanks all for the help. Is seafoam available locally or an internet item only?
  10. Oct 19, 2008 at 8:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can get it cheapest at wal mart...but autozone and most all auto parts store carry it.
  11. Oct 19, 2008 at 8:48 PM
    MyTaco
    Az
    08 Prerunner
    Very cool thanks....tomorrows project!
  12. Oct 19, 2008 at 8:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man. very easy to do.......but jsut a heads up......directions say to use some in the oil......unless you have alotta sludge build up, or you have really high miles, i wouldnt use it in the oil. it may clean good, but if the mileage is high, it could clean too good around the seals. just a possibility........and with these newer engines, i think with any good oil, its not really needed. now thru the brake booster and in the gas tank....most definitely.:)
  13. Oct 19, 2008 at 8:53 PM
    MyTaco
    Az
    08 Prerunner
