Excessive Play in Auto Transmission Shifter
Discussion in '1st Gen. Tacomas (1995-2004)' started by nzbrock, Apr 23, 2016.
  1. Apr 23, 2016 at 3:02 PM
    nzbrock
    nzbrock [OP] Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Ever since I have owned my Tacoma ('99 2.7L Auto TRD prerunner), it has had a lot of play in the transmission shifter. Without the truck on, I can wiggle the shifter front to back and side to side. Before you tell me this is normal, please look at the pictures and video. There are 4 bushings that support 2 bolts that connect the shifter selector to the transmission linkage.
    Part number is 9038511003
    I will update this thread when I install new bushings.
  2. Apr 23, 2016 at 4:55 PM
    nzbrock
    Noah
    San Marcos, TX
    mechanicjon and 99 tacomaguy like this.
  3. Apr 23, 2016 at 5:06 PM
    nzbrock
    Noah
    San Marcos, TX
    99 tacomaguy likes this.
  4. Apr 23, 2016 at 5:15 PM
    nzbrock
    Noah
    San Marcos, TX
    What the bushing should look like
    BarryF likes this.
  5. Apr 24, 2016 at 5:15 PM
    cj.ainsworth77
    cj.ainsworth77 Well-Known Member
    CJ
    Texas
    02 Reg Cab 2wd
    wow, mine does the same, and i was somewhat afraid the bushings underneath may have been worn...but, last time i had it racked rebuilding the starter, i noticed the shift linkage is bolted on, on the shifter end and the trans end...gotta love toyota
    what did these cost, btw?
    Black97v6MT likes this.
  6. Apr 25, 2016 at 5:19 AM
    nzbrock
    Noah
    San Marcos, TX
    They are about $1 a piece depending where you get them.
  7. Apr 25, 2016 at 5:22 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    My trucks have done this ever since I got them
  8. May 1, 2016 at 10:11 AM
    nzbrock
    Noah
    San Marcos, TX
    So I swapped out the bushing today in under 20 minutes. My shift now only has a tiny about of play from the whole linkage together. It is a night and day difference. I recommend doing this, it is very easy.
    All you need is:
    10mm socket
    12mm socket
    phillips screwdriver
    1. Mark the linkage under the truck and unbolt it.
    2. Remove shifter/cup holder cover.
    3. Disconnect main wiring harness from the shifter
    4. Unbolt all the bolts holding the shifter assembly to the floor.
    5. Remove shifter assembly so you can work on it out of the truck.
    6. Remove bolt that is directly under the shift lever, you have to unmount the white plastic interlock linkage so be able to slide the bolt all the way out.
    7. Remove bolt from the front of the shift linkage, access by pulling back the rubber boot.
    8. Install bushings into each end of each shifter linkage tube.
    9. Reassemble in reverse order.
    This is how I marked the shifter linkage under the truck.
    You can refer to the images in the first post for the location of the bushings.
    Black97v6MT and opteron like this.
  9. May 24, 2016 at 6:43 PM
    paposalsa
    paposalsa Well-Known Member
    Mine is a 2004, the issue since I'm picky is that when I take off the trans shift handle will move backwards or forward a little, the same when stopping. Looks like if I'm driving a stick, but I just notice today of the linkage from the transmission to the selector on the cab. I'm thinking I have some transmission mounting bushing going bad.... but I just bought this truck and not familiar....:confused:
    opteron likes this.
  10. May 25, 2016 at 4:05 AM
    smmarine
    Melbourne FL
    Mine does that, except the trans shifter moves backwards and the 4wd shifter moves forward. My Prerunner did the same thing. The trans is going to move a bit under torque
  11. May 25, 2016 at 5:01 AM
    nzbrock
    Noah
    San Marcos, TX
    Yes my transmission still moves a lot. However, replacing the bushings inside the cab on the shifter linkage almost completely stopped the shifter wiggle under torque.
    opteron likes this.
  12. May 25, 2016 at 7:21 AM
    paposalsa
    Does the bushing comes in a kit? Do you have a link for the repairs and/or the part numbers/ Thanks
    opteron likes this.
  13. May 25, 2016 at 7:59 AM
    nzbrock
    Noah
    San Marcos, TX
    The part number is in the first post. You just need 4 of them.
    opteron likes this.
  14. Jun 18, 2017 at 7:30 AM
    99 tacomaguy
    99 tacomaguy New Member
    99 tacoma 200,000 miles 4WD
    OME 2 inch lift
    Just wanted to say thanks to the nzbrock for the problem update, pics, and part numbers. We just picked up the four bushings.
    opteron and nzbrock[OP] like this.
  15. Mar 28, 2020 at 8:12 AM
    Dumpy
    Dumpy Active Member
    California
    01 black dbl 4x4 TRD limited
    Black Snugtop
    Great: Simple, Complete and no B.S.
    opteron likes this.
  16. Mar 28, 2020 at 9:53 AM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Thanks this is great, also found there is a light bulb there too. I always wondered why they never put a light bulb select shifter indicator. Adding to the list of things to fix.
  17. Jan 14, 2023 at 7:15 PM
    Colesingleton8
    Colesingleton8 New Member
    Cole
    1998 stock supercharged tacoma
    None
    I just ordered these today and am very excited to put them on. I'm new to this forum thing. I think it's going to help me alot!!!
  18. Jan 15, 2023 at 5:54 AM
    04SlugTruck
    04SlugTruck Active Member
    04 reg cab sr5 / 20 TRDSPTLB
    Great post, thank you! My 04 moves around quite a bit and jumps on takeoff/shifting - i will check this out
