Excuse my ignorance
Discussion in 'Suspension' started by Tacomotion, May 25, 2008.
  1. May 25, 2008 at 1:39 PM
    Tacomotion
    Tacomotion [OP] Member
    '07,TRD Sport
    3" Revtek lift,Heated leather seats fron and rear
    What exactly is this TSB everyone talks about? Where did it come from? How do you take advantage of it?
  2. May 25, 2008 at 1:52 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
  3. May 25, 2008 at 1:56 PM
    rick
    rick `
    search tsb list. or here ya go
    TSB = Technical Service Bulletin
    A TSB is not a recall.
    AU001-05 FEB 06 Audio System - Amplifier Won't Turn OFF/Battery Drain
    AU001-06 FEB 07 Audio System - Quick Reference Diagnostic Guide
    BO001-06 JAN 06 Body - Front/Rear Window Runs Deformed
    BO003-05 MAR 05 Body - Overfender Refinishing Process
    BO004-05 APR 05 Body - Water Leaks Onto Front Floor
    BO018-07 NOV 07 Body - Bent Rear Tailgate
    BO022-06 NOV 06 Interior - Driver's Side Lower Dash Panel Poor Fit
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
    EG021-06 APR 06 Exhaust System - Ticking Noise Between 2,000-2,500 RPM
    EG043-05 MAY 06 Fuel System - MIL ON/DTC's/No Start in Extreme Cold
    EG046-06 AUG 06 Intake System - Air Intake Hose Rattle
    NV003-06 MAR 06 Body - Front End Rattle/Squeak on Bumps
    NV004-06 MAY 06 Interior - Front Seat Squeak Noise
    NV006-07 AUG 07 Body - Windshield Wind Noise at Highway Speeds
    NV007-05 JUN 05 Body - Front/Rear Popping/Knocking Noise on Rough Roads
    NV007-07 JUL 07 Body - Dech Side Panel Rattle
    PD039-04 SEP 04 Pre Delivery - Initial Calibration Of Compass
    PD075-06 AUG 06 Pre Delivery - TPS Initialization Procedure
    PG004-06 NOV 06 General - TPS Diagnostic Tips
    SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
    SU002-05 NOV 05 Suspension - Rear Suspension Noise
    SU006-07 SEP 07 Suspension - Harsh Rear Spring Ride With Heavy Loads
    TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
    Each TSB can be read and / or downloaded here.
    In cases where a TSB has more than one revision I have uploaded the latest revision only.
    There are a few other TSBs that I do not have PDF files for.
  4. May 25, 2008 at 2:07 PM
    Tacomotion
    '07,TRD Sport
    Thanks for the info.
    I live in Canada, does the same apply here?
  5. May 25, 2008 at 2:23 PM
    tcBob
    Bob
    I believe so
  6. May 25, 2008 at 3:22 PM
    rick
    rick `
    some do. but i believe the suspension tsb doesn't. the canadian models have the upgrade
  7. May 25, 2008 at 3:36 PM
    Tacomotion
    '07,TRD Sport
