Exhaust - clamped or welded?
Discussion in 'Performance and Tuning' started by Scott B., Nov 9, 2018.
  1. Nov 9, 2018 at 5:50 AM
    Scott B.
    Scott B. [OP] Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    About 2 years ago, I installed a URD Spec-U exhaust (in anticipation of future upgrades. :))
    As delivered, the system is clamped together.
    Once I installed the system, and heat cycled it a few times, I tightened the clamps - as expected. About a year later, I checked the clamps, and all were fine. I noticed, however, some black carbon/soot on the exhaust pipe, right under the clamps. Apparently, over time, a very small amount of exhaust gases pass through the clamped connection.
    The leaks are not a problem, but leads one to think - should I go back and weld the joints?
    As is, if/when the time comes to replace a component of the system, the job is easy. Once welded, it is a very different story. But, when will have to change the muffler?
    Any thoughts, suggestions, insight appreciated.
  2. Nov 9, 2018 at 6:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    If they are not a problem..........
    Torspd likes this.
  3. Nov 17, 2018 at 9:30 PM
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    The black soot comes from the condensation in the exhaust and finds the path of least resistance out of all of the clamped pieces. If it doesn't bother you and you don't have any exhaust leak sounds I'd leave it as is for easier maintenance whenever the time comes.
    Roost
  4. Nov 18, 2018 at 5:27 PM
    Scott B.
    Scott
    Georgia
    Thanks. I figured it was something like that.
    Roostfactor[QUOTED] likes this.
  5. Nov 19, 2018 at 6:45 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I agree with leave it bolt on. Also allows room for some movement. Who knows, you might upgrade to a @Roostfactor y-pipe someday.
  6. Nov 20, 2018 at 6:03 AM
    Scott B.
    Scott
    Georgia
    Thanks. I appreciate the opinion. I think I will just leave it alone.
    Oh, I will have more questions for you two when I install my S/C... :)
  7. Nov 20, 2018 at 6:45 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Check out the s/c thread. Warning, deep rabbit hole.
  8. Nov 20, 2018 at 7:04 AM
    Scott B.
    Scott
    Georgia
    I've been reading it for a while now.
    I figured I wouldn't post in that thread until I was ready to install the s/c. It is sitting in the box in the basement. Just waiting...
    TitanRattler813 and Roostfactor like this.
  9. Nov 20, 2018 at 7:06 AM
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Feel free to chime in with questions. Very helpful dudes there. Think my coupler in my s/c went out just now. Guess I'm going to do some wrenching.
    inwood customs likes this.
  10. Nov 20, 2018 at 7:20 AM
    Roostfactor
    TX panhandle
    I installed the crank pulley, front intercooler, reservoir, inter cooler lines, and intercooler pump and harness (REMOVE FUSE) weeks before installing the blower.
    You can do these projects in smaller chunks of time so the main blower install is less time consuming. I just taped up the open intercooler hoses to keep the system sealed.
    BassAckwards and TitanRattler813 like this.
  11. Nov 20, 2018 at 7:28 AM
    Scott B.
    Scott
    Georgia
    That is a really good idea. One that I will be using...
  12. Nov 20, 2018 at 7:33 AM
    Roostfactor
    TX panhandle
    Glad to help!
