Exhaust Hangers: Tips for removal/installation?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hoopy Frood, Mar 20, 2018.
  1. Mar 20, 2018 at 6:41 AM
    Hoopy Frood
    Hoopy Frood [OP] Member
    2003 Tacoma (stock)
    Greetings! I'm needing to replace my muffler and tailpipe. There are three rubber hangers the muffler/tailpipe assembly slides into. I've never worked with hangers before. They're quite difficult to get the muffler/tailpipe support bars to slide out of/into.
    Apart from using a soapy water mixture for lubrication are there any tips you can offer to make the job easier?
    Thanks very much!
  2. Mar 20, 2018 at 6:44 AM
    TacoTRD78
    TacoTRD78 Well-Known Member
    Stuart,fl
    15 tacoma trd off road
    4X Innovations Sliders Tech deck Bilstein 5100's OME 885 CB radio install Rear diff breather mod After market front bumper lights Redline hood struts Shorty antenna door seal protectors Glove box/ Center console motion light Trailer harness plug relocation mod/Edit SOS HC rear bumper Ditch mount Lights with CBI brackets morimoto fog lights
    WD-40 use the red attachment spray in between rubber and hanger let it sit for like a minute easy peesy
  3. Mar 20, 2018 at 6:49 AM
    FickleHobbyist
    FickleHobbyist Active Member
    2018 Tacoma TRD OR DCLB 4x4, Cement Gray
    Stock
  4. Mar 20, 2018 at 6:51 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I use a quick spray of a penetrating lube like PB Blaster, work the bushing forward/back a couple times then it should pop right off. If not, repeat one more time with a little more lube.
    TacoTRD78 likes this.
  5. Mar 20, 2018 at 7:23 AM
    tony2018
    tony2018 Well-Known Member
    I second this, works EVERY TIME.
    TacoTRD78[QUOTED] likes this.
  6. Mar 21, 2018 at 12:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I just cut the old ones off What ever penetrate spray is handy But Silicone spray seems to be the best for installing new ones
  7. Mar 21, 2018 at 4:43 AM
    ggmanning
    ggmanning Well-Known Member
    07 FJC, 03 TRD Offroad, 11 TRDPro, 14 Landcruiser
    I use PB blaster and a flat screwdriver that can be crammed into the gap between the rubber and the metal pin. Pry them off in in just a few seconds.
  8. Mar 21, 2018 at 6:39 AM
    Hoopy Frood
    2003 Tacoma (stock)
    Thank you everyone for the replies! That is great info. Should be a snap. Cheers! :D
  9. Mar 24, 2018 at 10:03 AM
    Hoopy Frood
    2003 Tacoma (stock)
    I had all on hand, but thought I'd try the silicone spray first. Totally worked on the first try! Thank you so much!
    Now I have to get the muffler off the intermediate pipe. And no matter what I do I can't get it off. Ugh. Time for a new thread I guess.
    Thanks again!
    tony2018 likes this.
  10. Mar 24, 2018 at 2:21 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Are you sure it is not welded
    It has been so long they all start looking alike
  11. Mar 24, 2018 at 2:37 PM
    Hoopy Frood
    2003 Tacoma (stock)
    Yep. It was a u-bolt clamped connection between intermediate pipe and muffler. Got the clamp off but couldn't pull the two apart at first (but initial tries show it could move). A friends told me that it's not uncommon for some places to crimp the pipes when a u-bolt is used.
    I think that was the case in my instance. I'm going to update the other thread appropriately. But that spray silicone lube worked like magic on the rubber hangers at least!
