Exhaust Help
Discussion in 'Performance and Tuning' started by park713vmn, Jul 20, 2010.
  1. Jul 20, 2010 at 12:58 PM
    park713vmn
    park713vmn [OP] Member
    Hey guys, so I just added a Flowmaster 50 series to my '05 2.7 liter tacoma. It was a lot louder than I expected and has some popping when I shift. Has anyone else experienced this? When I went back to the shop the mechanic said this was a normal thing for 4 and 6 cylinder engines because of back pressure. He suggested a "turbo pipe" that is installed in front of the muffler, that would relieve exhaust noise and the popping by 50%, however you lose "performance" has anyone ever heard of this? And lastly, when I asked if adding a header would help alleviate any of the popping, he said if anything it would add more. Is there any truth to this? I also have an AFE pro dry-s if that makes a difference.
  2. Jul 20, 2010 at 1:03 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Sounds like he's suggesting a restrictor plate. That would certainly quiet it down and rob some of your performance.
  3. Jul 20, 2010 at 1:04 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    headers will most deff make it worse. the engine always pops, you just cant usually hear it because they are muffled. with a straight through or a muffler with minimal baffling it would be louder. headers add more flow which will make it louder yet. turbo pipe adds back pressure which in turn mufflers the popping but the additional back pressure will decrease performance. I have a magnaflow performance muffler that has very good flow and also has good baffling to muffle popping.
  4. Jul 20, 2010 at 3:49 PM
    park713vmn
    Thanks for the help so far guys. So perhaps a different exhaust is in order...
  5. Jul 20, 2010 at 3:58 PM
    park713vmn
    I was getting it more to help gas mileage. I didn't really think an exhaust system on a 4 cylinder would help all that much, but do you really think it will make it lose power?
  6. Jul 20, 2010 at 4:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, Flowmaster mufflers (most) cause a loss of performance. They are a baffled muffler, and actually have less CFM flow than the OEM one. What you need is a resonator installed after the muffler. Also..."Back pressure" should be very minimal in a modern engine, if any at all. Scavenging is what affects the performance of the engine.
  7. Jul 20, 2010 at 4:11 PM
    Yoytoda
    Roland
    completely stock
    with my magnaflow i got a 2-3mpg increase. also, i got a decent gain in power without excessive noice. the magnaflow was a perfect combo of performance power mpg and price
  8. Jul 20, 2010 at 5:11 PM
    park713vmn
    Thanks for the help guys. Looks like I'll be swapping for a magnaflow. Is there a particular model I should be looking for, do they have different series like flowmaster? Thanks again for all the help!
  9. Jul 20, 2010 at 5:31 PM
    Yoytoda
    Roland
    completely stock
  10. Jul 20, 2010 at 9:31 PM
    TacomaMtnMan
    TacomaMtnMan those who seek fear shall be followed by fear
    Chuck
    Broomfield
    Fox Shox lifted DC 4x4
    3" lift using Fox Shocks Coilover, Total Chaos UCA's. Running: Duratrac 285/70/17 Rear suspension just a 1" block for now. Will have custom rear springs no block. Fox w/ Resi.
    IMO I dont recommend Flowmaster for our trucks... like many have said these were designed for larger engines V8 +. Many with Flowmaster have complained of popping or ricey sounds on a V6 or smaller.
