Exhaust Manifold Replacement/EGR Gasket Issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cogneato, May 9, 2020.
  1. May 9, 2020 at 5:59 AM
    Cogneato
    Cogneato [OP] Active Member
    Justin
    Waco, Texas
    99 Prerunner SR5
    16" Duratracs, Westin Side Steps.
    So....I posted awhile ago about have exhaust manifold issues. Well the SOB cracked again so I returned it for a warranty replacement. This time, however, I replaced my motor mounts. I got the new manifold in, got it hooked up to the exhaust flange pipe, but the damn EGR gasket is incredibly difficult to install. Any tips on aligning the bolts from the egr to the manifold? I can get the bottom bolt to run but the top bolt just won't line up. Same thing happens if I secure the top bolt....bottom won't line up.
  2. May 9, 2020 at 8:45 AM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Not sure of your engine type but on the 3RZ's you would have to loosen the EGR bracket bolt on the back of the block to allow you "wiggle room" for flange alignment. I do stress "Loosen" bolt only since its extremely tight back there and its all by feel, bolt falls out and your cuss vocabulary will grow within a few minutes.
    lvs2rock likes this.
  3. May 9, 2020 at 9:03 AM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,2"pulley,meth, 650k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 650,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 2" pulley, methanol injected AC TRD supercharger,(MUST DO) TRD supercharger ported, rebuilt 3 times over 500,000 miles, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley,(300hp) (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, 4runner bucket seats, Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks chrome push bar, chrome nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Corbeau bucket seats Snow Methonal kit stage 2 Champion 3 core aluminum radiator Linex bed liner
    My EGR is different because it’s a v6, but I used a sealer on both sides of the gasket that holds it in place and seals it up better too.
    I forget the high temp sealer that I used tho, gray in color
  4. May 10, 2020 at 4:01 AM
    OLDHMECH61
    OLDHMECH61 Active Member
    Andy
    Odessa FL
    99 Prerunner std
    suspension exhst rims
    Go to NAPA with Your bolts and get studs and nuts of same size, thread studs into manifold put on gasket, now the two studs sticking out will act like a mounting perch, You will still have to wrestle it on there but the studs help....a lot, then install the nuts.
    Good luck
    Andy
