exhaust systems
Discussion in 'Performance and Tuning' started by samouhosvince, Apr 7, 2010.
  1. Apr 7, 2010 at 4:37 AM
    samouhosvince
    samouhosvince [OP] Member
    VINCE
    pittstown,nj
    2010 tocoma
    hey i have a 2010 4.0 tacoma im looking to get a different exhaust system. I dont want anything too loud, what do you reccomend?
  2. Apr 7, 2010 at 4:43 AM
    Jap
    Jap Loving this
    TRD supercharger, extractors, 7 psi pulley, Interceptor ECU
    You want performance or sound?
    If you're after mainly the latter, then just try getting your stock muffler swapped for a hi flow item.
    I put a 2.5" offset/offset hi flow muffler in my Hilux (same engine as yours) and it sounds pretty damn good.
  3. Apr 7, 2010 at 5:17 AM
    Brunes
    Brunes abides.
    Rotorhead
    Your goals/plans will determine what you need to get.
    If you are going to get a supercharger- Then you need to do that and then build exhaust to match what you want.
    If you are going to stay naturally aspirated: Get an upgraded muffler welded into the stock pipe system.
    For better performance: Dynomax Super Turbo
    For better sound: Flowmasters
  4. Apr 9, 2010 at 5:06 PM
    samouhosvince
    VINCE
    pittstown,nj
    2010 tocoma
    im looking for a good sound but mainly gas mileage and hp increaes.
  5. Apr 9, 2010 at 5:15 PM
    Tacofanatic05'
    Tacofanatic05' #1 Member
    Hunter
    Waynesville/Charlotte,NC
    05' Tacoma 4x4 sr5, 3 Inch lift
    16'' American Racing wheels, 285/75/16 Cooper Discoverer St tires, Bilstein 5100 w/eibach coils, K&N Cold Air Intake, Flowmaster Super 44, 1 in 2 out exhaust. Tractor Supply Tool Box, No Mud Flaps, Mossy Oak Seat Covers, Oakley Decals, Hoyt Decal, Window tint 20% on sides 5% on top front windshield, Uniden Cb, and Window Deflectors.
    to tell ya the truth there isn't much increase in gas milage or hp! Well at least I haven't noticed
  6. Apr 9, 2010 at 5:19 PM
    stenyeart
    stenyeart Well-Known Member
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    3" Toytec Lift w/ AAL, TRD CAI, Leer 700 Series, Hypertech Speedo Calibrator, Locker Anytime Mod, LR UCA's, OEM Roof Rack, Satoshi grill with Devil Horns Emblem, USA Spec PA-15 Toy Ipod Integration, Redline Tuning Hood Struts and EZ Down Tailgate.
    Smaller motors need back pressure, if you open them up you decrease the back pressure. This causes you to actually lose hp and gas mileage. With a V-6, I would just put on a hi flow muffler (I like flowmaster because of the sound) and leave everything else stock. Cat back systems for our trucks are a huge waste of money. New muffler and new tip, for looks, and be done with it. It will sound good.
  7. Apr 9, 2010 at 5:36 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    2-stroke motors "need" back pressure. 4-stroke needs efficient scavenging, in which back pressure only plays a small role.
  8. Apr 9, 2010 at 10:47 PM
    stenyeart
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    Put a 5" exhaust on a 4 cyl and then come talk to me.
  9. Apr 9, 2010 at 11:25 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    :laugh:
    ok...
    So tell me.. is it because of little backpressure or is it because the large volume of the piping has cooled the gas, which in turns slows down the exhaust velocity to the point that the exhaust scavenging pulse is no longer doing its job?
    What about a straight pipe 2" exhaust on that 4 cyl? it will have 0 back pressure. Will that still lose power? Why? ;)
  10. Apr 10, 2010 at 12:02 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Im digging my URD exhaust-----
    Its in my garage
  11. Apr 10, 2010 at 12:09 AM
    only_K
    only_K 1st Gen. Pride
    Kevin
    Turlock, CA
    99 Tacoma PreRunner
    K&N drop in filter, Magnaflow Exhaust, Billet grille. All 4 Bilstien 5100s. Fronts set at 2.5". Rear 2" AAL.
    Magnaflow is what you want. Nice mellow tone. Not too loud, and not too quiet. When you floor it it will sound even better.
  12. Apr 10, 2010 at 12:54 AM
    stenyeart
    Sean
    Lewiston, Idaho
    06 DC TRD OR SWB
    Just taking the muffler out does not give you zero back pressure.
  13. Apr 25, 2010 at 7:01 PM
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    Bigger is not always better when it comes to exhaust. Depending upon the variables of the engine components, more back-pressure/restriction may be needed to achieve optimum exhaust velocity.
    In High performance situations, bigger exhaust usually is better because even though larger in diameter, the exhaust maintains enough velocity. But, in smaller & less powerful motors, you need to find the right balance between free -systems and restrictive systems in order to maintain optimum velocity in the RPM band that you make power in (lower RPMS usually).
  14. Apr 25, 2010 at 7:05 PM
    Brunes
    Brunes abides.
    Rotorhead
    But putting a Flowmaster muffler into your rig makes TONS of backpressure. Flowmaster is a "high flow" muffler with tons of baffling to make the great sound.
    Dyno sheets have been posted in the past to prove a LOSS of HP/TQ with Flowcrapsters. If sound is your thing- Go for it. But don't try to lecture about performance if you are backing Flowmaster,
