exhaust tip?! Do they change exhaust sound?
Discussion in 'Performance and Tuning' started by kajun123, Jun 30, 2008.
  1. Jun 30, 2008 at 6:53 PM
    kajun123
    kajun123 [OP] CHEROKEE
    houston, texas
    2007 4 dr tan 4.0
    stock for now
    I just recently installed the flowmaster original 40's on my truck and i wanted to know if tips actually effect the way it sounds at all?! Any input or first hand experience with this is greatly appreciated!
  2. Jun 30, 2008 at 6:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  3. Jun 30, 2008 at 6:55 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I have factory exhaust, but I am thinking the sound comes from with in the system, by the time it reaches the tip, the sound has already been produced.
  4. Jun 30, 2008 at 7:01 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Ah but the final cut end DOES affect the sound to a degree Gentlemen!! A straight cut will produce more of a 'rappy' tone whereas the slant cut will produce more of the mellow drone!! That's why I chose 'bologna cut' tips so as to eliminate the choppy rapptone-I just get that custom baritone effect:)
  5. Jun 30, 2008 at 7:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok, Frank. What have you been drinking. :)
  6. Jun 30, 2008 at 7:13 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    If you mean alcohol, I don't drink a drop. I also dont take or smoke drugs. When I got my duals he originally put straight cuts on-then showed me the difference in tone when fitting slants on it. When I asked him how that could be-he said since all the sound is coming out at that point, the shape and size of the tips can make a difference in what he referred to as 'punctuation' of the exhaust tone.
  7. Jun 30, 2008 at 7:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    WOW! I didnt know that! I thought you were being funny. :D Im gonna try that the next time Im playing with an exhaust system. I happen to always use the "slash" cut tips. I think a 15* angle looks good. My Tacoma came with the polished stainless "rolled" tip. One of the things I need to get is a Decible meter, so I can accuratley gauge the sound of an exhaust system I build.
  8. Jun 30, 2008 at 7:25 PM
    concrete jedi
    Rochester N.Y
    MMM ! bologna :drool:
  9. Jun 30, 2008 at 7:58 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Anyone skeptical about what I said, type "do exhaust tips change tone?" into your search engine and see what comes up:D it aint as nutty as it sounds
  10. Jul 1, 2008 at 12:30 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Seem's that search came up about 50-50 on just for looks or actually did change the sound. I'm thinking the one's with a resonator in them would make it some what lower in pitch as would welded on vs. bolted on as to the sound pitch or resonance? The shape would be more as to how the final sound was directed away from the vehicle.
    Probably perceived volume by shape as well. I've had turnout mufflers on some bikes that really gave your right ear a workout compared to the straight back ones with different end caps. If you were 30 foot from the bike they were the same loudness? But what a difference riding it.
  11. Jul 1, 2008 at 12:56 PM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    The tip will not effect the sound unless you stick a baffle in the tip. The tip is cosmetic only.
  12. Jul 1, 2008 at 1:28 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Except on ridgerunner's truck because he's.....special:D
  13. Jul 1, 2008 at 1:31 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    They also produce mad horsepower gains.
  14. Jul 1, 2008 at 1:40 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I should add here that this is MY experience. Both pipes exit on the passenger side. I stood by as the exhaust guy drove my truck past me to the end of the lot. Under load, there was more of a raspy 'popping' coming off the straight-cut tips than from the slashcuts. That is why I chose the slashcuts. I guess the angle of the cut 'smooths' the flow of air out that pipe edge...also the edges of the straightcuts had a rolled 'lip' that the slashes didn't. That can probably cause some reverb too.
  15. Jul 1, 2008 at 1:44 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    What are you implying?
  16. Jul 1, 2008 at 4:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, I knew that the exhaust tips shape and size, as well as how long after the muffler, has an affect on the performance of the exhaust, so it just makes sence that it would affect sound. My hearing is not that good, so that could explain why I have never noticed it. FOr those that may have some doubts, check this out:
    http://www.automedia.com/Exhaust_Tips_and_Tricks/pht20050801et/1
  17. Jul 1, 2008 at 4:51 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I gotta say Thanks Chris for jumping in:) YOUR SITE even said the "punctuation" thing!! I started feeling the gangup here-but I know what I hear on my truck. But I still have to learn when to shut up!:(
  18. Jul 1, 2008 at 4:55 PM
    rick
    rick `
    the tip makes it look like it sounds better
  19. Jul 1, 2008 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just doing my job.:cool:
  20. Jul 1, 2008 at 4:58 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    +1 on all here:) and you have DIRECT experience with perhaps the loudest set of pipes as examples!
