Exhaust tip inlet diameter?
Discussion in 'Performance and Tuning' started by Rucas, Feb 14, 2010.
  1. Feb 14, 2010 at 4:24 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    OKay i looked through thr threads and am still confused?
    What i want to do is cut off the end portion of my exhaust and put a new tip on.
    I measured for sizes by doing:
    Pi X Diameter = Circumference
    or,
    Diameter = circumference/Pi
    For the very end, the "flared" out part we got a pretty good circumference of 8.5in, so that would make the diameter 2.7 inches.
    For the regular pipe size the circumference we got was 7.5in, making the diameter ~ 2.4.
    So i want to know what inlet size on the new tip i should be getting? And what are the exact values?
    thx
  2. Feb 14, 2010 at 4:35 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Why are you doing all this math!?? Measure one side to the other? No one makes a 2.4" exhaust. Most likey 2.5", so that would be your inlet.
  3. Feb 14, 2010 at 4:48 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    aaahaha. i know they dont make 2.4 or 2.7 sizes, but i just didnt know which was right?
  4. Feb 14, 2010 at 4:49 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    SO did this 2.25" one slip on?
  5. Feb 14, 2010 at 4:52 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    on summit racings site there 2.410" inlet diameters
  6. Feb 14, 2010 at 6:11 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    any more input on which size to get for clamp on tip?
  7. Feb 14, 2010 at 9:06 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    chop off the flared end, get a tip with a 2.25" inlet. Call it a day. :thumbsup:
  8. Feb 14, 2010 at 10:58 PM
    Rucas
    Rucas [OP] 1st gen
    Lucas
    1st gen. 4x4
    okay thanks!
  9. Feb 15, 2010 at 8:26 AM
    dually
    dually Low and slow
    So this is stock exhaust? If so, then yes 2.25...
  10. Sep 22, 2012 at 1:35 PM
    Tenmile Tacoma
    Tenmile Tacoma Well-Known Member
    Nate
    Denver, CO
    2016 DCLB TRD Sport 4x4
    3 in Bilstein lift (6112s front, 5100s rear w/ 1.5in AAL) 285/70R17 KO2 RCI Rock Sliders & Engine Skid REKGEN Mudflaps K&N CAI
    ok so I got a 12" gibson 2.25 inlet clamp on exhaust tip and the damn thing won't fit on!! I cut off the flare and even filed the end of the stock exhaust a bit, but it will not go on. While trying to put it on I also opened the clamp end a bit more with a chisel, yet it still wont go on! What should I do?
