Expedition leaves and shackles
Discussion in 'Suspension' started by malander, Apr 18, 2011.
  1. Apr 18, 2011 at 6:31 PM
    malander
    malander [OP] Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I realized I was crowding up another thread trying to find an answer to this issue so I thought I would make my own thread.
    I'd like to run the allpro expedition leaf pack soon and I want some greaseable shackles as well. I could buy oem length greaseable ones from wheelers for 100 something bucks but I'd rather keep what I can keep and replace what I have to replace.
    The allpro expedition "kit" includes bushings for the expos so I was thinking I could just purchase the greaseable shackle bolts they sell and use those combined with the expo bushings on my stock shackles.
    I contacted allpro about this and I don't think they understood what I meant, they said something along the lines of "all of our shackles are greaseable, no need to buy the bolts something something something". I just sent another email to give a little clarification and I hope to get an answer soon, but until then what do you guys think? Anyone know if this will work?
  2. Apr 18, 2011 at 6:40 PM
    brelandt
    brelandt Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    No the stock shackles have the bolts welded to one of the arms. At least that is the way they are on mine. I bought the lift shackles from wheelers and started to install them before I realized I HAD to remove the old bushings in order for the new greable bolts to work and I don't have the time to burn those out so they are sitting in the garage for now.
  3. Apr 25, 2011 at 7:46 PM
    TacoSID138
    TacoSID138 Well-Known Member
    SoCal
    04 PreRunner TRD
    Faded out tinted tails and 3rd brake light,deck-plate mod, dumped Flow Master 40, King EXTD coil overs, 1.5 AP shackles, AP EXPD leafs. 285 Hankook DynaPro ATM tires
    I'd like to know this too. That leaf pack alone is quite a bit of money. I would like to use whatever I can, my truck only has 76k.
  4. Apr 25, 2011 at 7:55 PM
    malander
    max
    01 limited trd 4x4
    So you're saying that the bolt itself was welded to the shackle arm?
  5. Apr 25, 2011 at 8:06 PM
    brelandt
    Terry
    Dublin, CA
    yep.....
    stock shackles have both bolts welded to the arms so you will need to replace the whole thing if you want greaseable bolts. Like I said I have a kit from wheelers so I know. Let me know if you need an other advice on these.
  6. Apr 25, 2011 at 8:08 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    look into defined engineering stock length shackles, greasable with delrin bushings
  7. Apr 25, 2011 at 9:49 PM
    TacoSID138
    SoCal
    04 PreRunner TRD
    What's the difference between the stock shackles and the greasable shackles?? if you don't mind me asking.... Is there a pro to the greasable ones?
  8. Apr 25, 2011 at 9:53 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    they are only for second gens
  9. Apr 25, 2011 at 10:24 PM
    PLC721
    Patrick
    Chandler, Az
    My bad didn't even see what OP had. Sorry:eek:
  10. Apr 26, 2011 at 6:27 AM
    malander
    max
    01 limited trd 4x4
    Serviceability mainly but at this put I really don't give a shit, I've sent too many emails and spent way too much time trying to figure this out so I think for now I'm just keeping my stock shackles and lubing the hell out of the bushings when I do my spring install.
  11. Apr 26, 2011 at 6:33 AM
    brelandt
    Terry
    Dublin, CA
    main difference is that greaseable bolts are hollow therefore they are bigger in diameter than the stock bolts. then the leafs themselves have steel bushings in them that is not big enough for the greaseable bolts to fit through. You will need to remove the stock bushings by burning them out and using the poly bushings that come with the new shackle kit.
