Experience with Superior 1000lb Helper Springs?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by el_smurfo, Aug 4, 2017.
  1. Aug 4, 2017 at 3:19 PM
    el_smurfo
    el_smurfo [OP] Well-Known Member
  2. Aug 5, 2017 at 10:05 AM
    HawkShot99
    HawkShot99 Well-Known Member
    Poughkeepsie, NY
    13' Silver DCLB TRD Sport
    I have been looking at the hellwig helpers a bunch lately. I do not want to lift my truck, just fix the sag.
    What makes you want 1/2 helper springs vs full? It shows a weight 550# vs 2000# on the helwigs, but not really sure what they mean.
    I run a Leer cap on my truck that I estimate at 200-250#'s. I also have a sleep platform made from metal and plywood that I estimate at 150#'s. I tow a small 5x8 enclosed trailer with my mower in it that is about 2000#'s.
    Not sure if the 1/2 springs are enough, or do I need the full springs.
    I emailed hellwig to ask their thoughts but have not heard back yet.
  3. Aug 5, 2017 at 12:25 PM
    el_smurfo
    I want the half because I am a timid mechanic with a very sloped driveway. The 1/2 can be installed without touching the axle ubolts, just bolt right on. I just want mine to reduce a little bounce when towing, but I read they are better for your application of restoring spring height from bed loads.
    HawkShot99 likes this.
  4. Aug 5, 2017 at 1:36 PM
    ABNFDC
    ABNFDC Well-Known Member
    Granite State
    2008 4WD Access Cab TRD OR "Rugged Trail"
    265/75/16 Wildpeaks, Dakar rear, HS 2.5" front coils
    If it matters to you, the Superior springs look silver, when the Hellwigs are black.
    I had Hellwwig 550s on my truck a long time ago, but eventually replaced it with a complete AAL.
    I'm tempted to buy another set just for piece of mind on my next move. I'm guesstimating over 3K pounds of stuff and that's in addition to the almost 2K pound uhaul trailer.
