extend the oil change with synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Oct 6, 2012.
  1. Oct 6, 2012 at 5:10 PM
    bra
    bra [OP] Well-Known Member
    2008 AC 4X4 TRD sport
    Badges off
  2. Oct 6, 2012 at 5:22 PM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    I still go 5000 between changes, which is only about twice a year for me.
  3. Oct 6, 2012 at 5:25 PM
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    i run sythetic and change every 3000
  4. Oct 6, 2012 at 5:28 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Chang filter at 5K oil at 10k.. Down here in the heat I run 10w30
  5. Oct 6, 2012 at 5:30 PM
    John3
    John3 Well-Known Member
    Maryland
    Barcelona Red 2010 DCSB TRD Sport
    OME 884X Coil Springs, CS047 Dakar Leaf Springs, 90000 Nitrocharger Sport Front Shocks and N182 Nitrocharger Rear Shocks, Light Racing UCAs, WeatherTech Floor Liners, Leer 100XQ Cap, 3/4" Plywood Carpeted Bed Platform, Thule Rack System w/4 Rocky Mounts PitchFork bike mounts, Pop & Lock PL5300, rcbs204 4x4 Illuminated Switch Mod, Dome Light Mod, Fog Light Mod, FLYZEYE Designs TCMA-0511 V2W LED Light, Go Rhino Dominator II SideSteps, HitchSafe, Console Vault, Fumoto F-103N Oil Drain Valve
    Full synthetic change every 5000 miles per the owners manual. Don't trust extended OCI without an analysis.
  6. Oct 6, 2012 at 5:30 PM
    Larry
    Larry CARL
    CARL
    I changed out the dino for syn at 1K miles...and will change at 5K miles and every 5K miles.
  7. Oct 6, 2012 at 5:40 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Toyota now pays for maintenance for new cars for the first two years. Toyota now has an incentive to extend the published OCI as long as possible.
  8. Oct 6, 2012 at 5:43 PM
    bra
    Badges off
    And what will happen if I extend? Does it wear the engine or parts inside? Or the performance?
  9. Oct 6, 2012 at 6:05 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Do oil analysis if you're worried about it but I change it every 5k-7k. I'm almost to 7k on my oil now and it looks brand new (which is really no indication of wear but still).
  10. Oct 6, 2012 at 6:09 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    So after changing the filter do you just add some more synthetic to make sure you're at correct level? As I'm sure you would lose some oil that's in the filter
  11. Oct 6, 2012 at 6:20 PM
    KenLyns
    Belly of the Beast
    ^Yup.
  12. Oct 6, 2012 at 6:23 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm running Mobil 1 and change the oil and filter at 7,500 miles.
  13. Oct 6, 2012 at 6:31 PM
    jtgroce
    jtgroce Got R Did
    This is what I was thinking about doing, just wasn't sure if the filter perform at it's best after 5k miles
  14. Oct 6, 2012 at 8:19 PM
    Larry
    Larry CARL
    CARL
    doesn't the consumer pay for it as part of the Toyoguard?
  15. Oct 6, 2012 at 9:00 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Analysis is great, but at $25, it's only another $15 to just change it ;)
    Seriously... Change intervals beyond 15k are possible with a proper bypass filtration system installed. The cost of the system, plus the cost of the UOA, on a truck that only takes a $4 filter and $30 worth of synthetic 5w30/0w20, it's not worth it.
    It's getting to be worth it on a 10-quart Duramax or 12-quart Powerjoke, but it really is not truly economically advantageous unless you're talking about long-haul OTR trucks that carry 10 gallons of oil... and can then run 60k between changes.
    Synthetic oil is good. It's freaking awesome. It has a lower cold pour point for better protection in cold weather. It has better film retention, which reduces wear during the first seconds of operation following a cold startup. It has better shear stability due to the reduced percentage of viscosity improvers that are needed to create a multigrade oil.
    All of the above allow it to be used for extended change intervals... and that is what has been pushed by Mobil and Amsoil, because one $45 oil change every 15,000 miles compared to three $20 oil changes every 15,000 miles makes synthetic look cheaper.
    But extended OCI is NOT, and never has been the primary benefit of synthetic.
    I run synthetic and change at 5k.
  16. Oct 6, 2012 at 9:30 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    Im sorry but this soon is not only a waste of time and money, but it also wastes oil and filters. 5 thousand miles is the new norm, unless your towing in the desert.
  17. Oct 6, 2012 at 9:58 PM
    MrTacoma
    MrTacoma Well-Known Member
    Tacoma Base v6
    None
    This might be wrong Thread but out of curisosity, does Toyota, or the Tacoma Owner Manual state anywhere that our trucks can take Sythetic Oil ? I dont disagree with it, with all the info I know about sythetic in theory it sounds great and better for the engine, Im hesistant to do it because I havent found it in the manual saying its ok for the engine..
  18. Oct 6, 2012 at 10:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Some of the newer models specify 0w20 oil.
    0w oils are only available as synthetic.
    Therefore: 0w20 spec = synthetic.
    I believe this applies to the 2012 and later 2.7 on the factory fill, but Toyota spec's 0w20 as acceptable as far back as 2005 on the 2.7 and 2010 on the 4.0.
  19. Oct 6, 2012 at 10:25 PM
    monsterkx2fiddy
    monsterkx2fiddy Well-Known Member
    Birthplace of Davy Crockett
    Oil is oil. Synthetic has longer lasting lubracative properties. That's why it lsat longer. Usually a manual will say switch to synthetic after 40 or 60k. I switched to synthetic because I want my truck to be protected. Simply can't go wrong with synthetic.
  20. Oct 6, 2012 at 11:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No it won't.
    Agreed ;)
