extend the oil change with synthetic oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bra, Oct 6, 2012.
  1. Oct 7, 2012 at 3:48 PM
    bra
    bra [OP] Well-Known Member
    2008 TRD sport access cab
    Smoked headlights with White DTRL, Michelin
    And if I live in tropical weather where the winter doen't exist, is it better to use 5W40 instead of 5W30? Will the 5W30 be better for MPG?
  2. Oct 7, 2012 at 3:50 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I would not use anything heavier than 5w30 in any gasoline engine.
    5w40 is for Diesel engines.
  3. Oct 7, 2012 at 3:59 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    i cjange mine once a year.:cool:
    amsoil 0-30
  4. Oct 7, 2012 at 4:28 PM
    Fury
    Fury Well-Known Member
    Hi all.
    Lets remember guys, the time constraint ...
    The recommended interval (for the 1GR) is every 8000 km (5 thousand miles) or every 6 months, whichever comes first.
    For those of us who do our own services and get less than 5000 miles every 6 months, the time interval is critical during the warranty period. If something goes wrong and you don't have documentation stating you did the services every 6 months, regardless of the mileage, your warranty may be deemed void by Toyota.
    Personally, I get much less than 5000 miles in a year but I will still do an oil and filter change with full synthetic every 6 months (spring and fall) as per Toyota's recommendation. I could care less if I'm called fanatical on my maintenance because the oil coming out of the drain plug looks the same as the stuff coming out of the jug ... :p
    Cheers
    Ray.
  5. Oct 27, 2012 at 1:25 PM
    fadippides
    fadippides Well-Known Member
    NEPA
    12 TRD Off Road
    Rather then starting a new thread i figured Id post here. I just changed to Mobil 1 EP and plan to run at longer intervals. I am at 30K and have the extended to 125K, I figure if I am ever denied a claim due to the longer intervals, it would be backed by Mobil 1 EPs warranty for 15K miles (I will probably change every 10K).
    Edit: I drive about 180 miles a day, all highway, little traffic.
  6. Oct 27, 2012 at 1:50 PM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    My wife and I have "Toyota Care" on our 2012's. Free maintenance for 2 years or 25,000 miles. No Toyoguard and no additional cost.
  7. Oct 27, 2012 at 4:23 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    You won't be.
    Mobil says to stick with manufacturer-recommended intervals during warranty.
    Also, read the fine print in your 125k extended. Extended warranties are not "warranties"... they are service contracts. They are not covered by Manusson-Moss, and if the policy says 5k, it means 5k... not 5k unless synthetic or not 5k unless Mobil says 15k.
    But Mobil absolutely does NOT have your back while you are still under warranty.
  8. Oct 27, 2012 at 7:03 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
  9. Oct 27, 2012 at 9:19 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    UOA looks great... holds viscosity very well (though would be nice to see a VOA for comparison).
    But 10k intervals are not an issue... and really doesn't need the M1 "EP" tagged products. Additionally, Toyota supports 10k intervals for the 2012 and later model 2.7 engines running 0w20 synthetic.
  10. Oct 28, 2012 at 5:20 AM
    fadippides
    NEPA
    12 TRD Off Road
    Here is Mobil's coverage period (from their warranty):
    The Mobil 1 Extended Performance limited warranty is valid for 15,000 miles or your vehicle’s OEM recommended oil change interval, whichever is longer. You do bring up a good point of Manusson-Moss, I will have to check the wording of the service contract.
  11. Oct 28, 2012 at 5:47 AM
    NWTacoGuy
    NWTacoGuy Well-Known Member
    James
    Pacific North West
    2010 TRD Off Road DCSB
    Fabtech 6", xd addicts/35x11.50 Nitto Terra Grapplers, Black badges, Pioneer HU, 11' grille, ect ect ect....
  12. Oct 28, 2012 at 6:29 AM
    qnyla
    NM
