Extended Brake Lines?
Discussion in 'Suspension' started by BlueSteel, Nov 26, 2011.
  1. Nov 26, 2011 at 10:35 AM
    BlueSteel
    BlueSteel [OP] Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
  2. Dec 17, 2011 at 10:59 AM
    BlueSteel
    James
    The Woodlands, TX
    Bump. I checked with Camburg and they didn't know the exact extension for the front lines other than a 4" spindles need 4" extended brake lines, but I have seen some of the brake lines showing a 2" extension for lifts. Anyone know exactly for front and rear length? Are 2" lines recommended front and rear for this lift setup? I will probably just do the expo leafs without the block and the camburg spindles with CO's set to 1".
  3. Dec 17, 2011 at 12:54 PM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    When I called Camburg they said that their extended front lines are 17" overall length. I would call them again and double check just to be safe.
  4. Dec 19, 2011 at 11:18 AM
    BlueSteel
    James
    The Woodlands, TX
    Thanks for the information. I spoke with Camburg today and they said that their extended front brake lines are 17" long, around 4" over stock. I was also told that no rear brake lines were needed, but I will pick up a set of 2" extended lines for the rear anyways just to help out with the added height.
  5. Dec 19, 2011 at 6:32 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Rear lines are definitely needed! I think all pro sells 8" ones in their kit!
