Extended brake necessary lines for a 3" lift ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Razorecko, Jun 30, 2009.
  1. Jun 30, 2009 at 8:11 AM
    Razorecko
    Razorecko [OP] Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    Thats the question - i ordered my toytec 3" lift kit but I wanted to know if the oem brake lines will suffice for that lift or will i need longer ss lines ?
  2. Jun 30, 2009 at 8:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OEM will be fine.
  3. Jun 30, 2009 at 8:14 AM
    Razorecko
    ^ thanks !
  4. Jun 30, 2009 at 8:15 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Stock are fine. I did add the extended ones just because.
  5. Jun 30, 2009 at 8:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Extended lines are good cause they are usually stainless steel braided...which improve braking response.
    Not necessary...but I'd recommend them. The set on my sport bike have saved my life several times.
  6. Jun 30, 2009 at 8:19 AM
    Razorecko
    I had a set of ss lines on my jeep srt8 and when i hit a large dip in the road and got some air the ss line snapped because it didnt have the flexibility of a rubber line. That was a defect in the manufacturer of the ss lines but it just shows that there are downfalls to even ss lines
  7. Jun 30, 2009 at 8:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It may have snapped due to over extension. SS lines are Braided to allow flexing in the line, just not axpansion due to line pressure.
  8. Jun 30, 2009 at 8:24 AM
    Razorecko
    yep
  9. Jun 30, 2009 at 8:31 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    You were airborne in a Jeep ...There aren't MANY stock replacement parts that could withstand that or are designed for it. You called it a "defect" in SS lines, paired with an unintentional mis-use of your ride-Sounds like a singular event. Folks use SS lines in desert runners and race trucks all the time.
  10. Jun 30, 2009 at 8:35 AM
    Razorecko
    Yea i think the manufacturer never extended the length of the line to accomodate such a "freak incident" - lol wasn't fun landing either - got a good inch or 2 in the air for a few feet. Landed and barely got back straight after squiggling around the road a little
  11. Jun 30, 2009 at 8:40 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...That sounds like a miserable ride. I woulda shit myself I'm pretty sure.
  12. Jun 30, 2009 at 8:42 AM
    Razorecko
    Luckily at the time i had 315/285 tires and the suspension was pretty modified. I do miss the jeep for that reason, it handled incredibly for such pig with some links, bars, etc
  13. Jun 30, 2009 at 9:02 AM
    tlmotorsport
    tlmotorsport Active Member
    St. Louis
    08 4x4 Doublecab w/ offroad package
    I've seen/heard of more failures due to a SS line than OEMs, my racecar (which I have plenty of good pedal feel in) has oem rubber lines. I generally consider that good fluid condition is gonna have a bigger impact along with ratio of piston areas(master cylinder to calipers).
  14. Jun 30, 2009 at 9:08 AM
    Razorecko
    I agree. After that incident ss lines really isn't that important in my opinion. Some good Dot4 and proper caliper/pad setup/compound is more ideal
  15. Jun 30, 2009 at 9:11 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Whatever makes you happy.
  16. Jun 30, 2009 at 9:22 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    +1
    All of my most recent dragsters have had full braided SS setups as required by the rule book. At one point in time this was not mandatory, since going to the full braided setup we have had more line leaks then ever before. :rolleyes: Go figure.
    The braided lines are Russell's so quality is definitely not the issue here.
